Re: error 990
My printer has err 990?
  • ehemingway Feb 21, 2008
    Printer Ricoh GX3050x -----err 990
    Genius:
  • 1,019 Answers
Could you be more Specific. Printer Make-Model Et,c.
is it HP-Cannon-Epson et,c.
Thanks mike.
Posted on Feb 21, 2008
  • Mike Waldron Feb 22, 2008
    The only documentation i,ve located. is that the 990 error is related to a coupling. ** please read Taken From An Article:-
    The coupling is a mechanical device that engages the OPC drum in each toner cartridge with the drive block once the carriage has properly positioned the toner cartridge with the transfer belt. This position is determined by the carriage detect ribs that pass through a home position photo sensor. All these ribs are the same size except one. This longer detect rib is home position and is located near the magenta cartridge slot on the carriage. When this longer rib passes through the home position sensor, the cyan cartridge is engaged by the coupling to begin its share of the writing and primary transfer process. As each color comes into position, the coupling motor rotates a cam that locks the carriage in place and engages each OPC drum. When the carriage is ready to rotate to the next color, the coupling motor reverses to disengage the coupling.
    The coupling position is detected by the “coupling on” sensor, or the “coupling off” sensor. If either one of these sensors does not see the sensor flag when it is supposed to, a 990 error is shown on the display. If either of the sensors is bad, a 991 error will be displayed. For troubleshooting these two errors, Hope this has helped to resolve your Problem.
    Mike @ Compurepair.
Oki c321dn 'service call 990:error'
Error 990 refers to the toner capture sensor unit, that black knob looking thing on the toner cartridge itself. I'm betting the error popped up right after changing the toner cartridge?..... therefore, it's a defective toner cartridge.
Aug 14, 2014 | Office Equipment & Supplies
Ricoh Gx7000 inkjet A3 Printer - what does 'error 990' mean?
Error 990 indicates a dirty sensor, so either a maintenance unit is dirty or you have a clogged print head. You can read more about this error on Richo website where you can see in the images what you need to clean.
Feb 13, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
How to fix error 990???
http://forums.linux-foundation.org/read.php?30,2996 Date: October 31, 2008 02:18PM
ERR (990) ??? I turned it off and back on & still gives me this error code?
Date: January 09, 2009 03:26PM
This is a known manufacturer error. Call Ricoh Direct and talk to someone in Tech Support. If your product is registered with them, they will send you a new printer. You will have to ship the old one back in the same box the new one was shipped to you in, but they provide an RMA # so there isn't any charge.
Jan 11, 2011 | Ricoh Aficio GX3050N All-In-One Printer
The Ricoh printer is showing an erro 0f 990. its gx3050n believe a 2007 model.
Jan 11, 2011 | Ricoh Office Equipment & Supplies
Error 990 on Ricoh printer .What is the problem??
Error 990 means the problem is with the scanning unit which is basically called a laser unit as well that requires a replacement.
Thanks and regards,
Anil.B.R
Oct 27, 2010 | Ricoh Aficio GX3050N Printer
Error 990 keeps blinking on machine
This is an error that has to do with the ink drying up on the maintenance unit. This cannot be fixed by the end user and must be fixed by Ricoh. Error 990 is a Ricoh defect in which the printer should qualify for replacement.
Feb 12, 2010 | Ricoh Aficio GX5050N Printer
Printer will not print and shows an error message ERR 990
epson R1900 printer head was blocket on the left side of printer ond dont runing
May 25, 2009 | Savin 3350DNP Laser Printer
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Ricoh GX3000
ERR (990) or ERR (999) are both error messages which are displayed when a sensor does not work normally due to dirtiness. For example, either may be caused by a dirty maintenance unit or clogged ink nozzles. It may be possible to resolve the issue by cleaning the device
look here for instructions:
http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Jan 25, 2008 | Ricoh Aficio GX3000 All-In-One Printer
Computers & Internet Logo
351 people viewed this question
David Payne
David Payne
