Blue shadow 50
I have a blue shadow on my 50" widescreen Sony TV that I bought new 6 years ago. I shut the TV off and 45 minutes later in went away a when I turned it back on but only for a few minutes. What can I do?
5 Suggested Answers
SOURCE: RCA 50" widescreen model M50WH74S Quit working
the deflection board put set into shut down,should be under warranty for service.
Posted on Sep 15, 2007
  • 39 Answers
SOURCE: Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Posted on Dec 14, 2007
SOURCE: RCA HD61W66 Turns on then cuts off I NEED SOME HELP
Ive had a similar model since 2002 and it had the same problem. Factory power supply to weak for the model. Mine was replaced twice before the upgrade came out. Sorry, I dont think it is a $.50 solution.
Posted on Jun 19, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Blue Shadowing on Flat Panel 50"
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
I have a 46 inch Sony Bravia. It is several years old. Maybe 5? A few years ago the screen was replaced under the extended warranty we bought from Target. The problem started out as shadows on the screen....
Is it a perfect square like there is a box on the screen ? if so it could be an easy fix if not then time for a new TV!! Did it just slowy get worse or was it just like that one day?
Nov 17, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Green lines vertical on lg 50 plasma tv started with one thin one week or two later developed another one what can i do to fix the problem
I had the same problem with a Sony tv a couple of years ago. The cable connection was going through the VCR, then to the tv, so we thought we could try making a direct connnection, and the lines went away! I'm not sure if this is your problem, but if so, this should do the trick. If not, call a repairman, and they may be able to help.
May 29, 2011 | LG 50PX1D 50 in. Plasma Television
My grand wega 42" rear
call sony. they have been offering new tvs at a discounted price for that problem. whatever they offer take asap. yes its a throwaway tv. sony the only company that is helping customers with that problem, other manufacturers say tuff. 18002822848.
Mar 22, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
My TV is a Sony Grand Wega KDF-42WE655. I purchased the TV new 5 1/2 years ago and have had to replace the bulb once at the beginning of this year. I have a blue shadow on the bottom right corner on the...
The blue shadow is a sign of a bad light engine. this is a common problem for this model. Fixing this type of problem is quite expensive. Light engine Costs you several hundred of dollars nearly to the price of new TV set.
Nov 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Apr 20, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
I have more and more tiny bright blue dots
hello it may be the light engine that's faulty
shaun
Sep 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Plays a/v for a min, turns off standby light blinks 45 times
If you have never replaced the lamp before its likely to be close to the end of its usable life. best to replace it, the ballast in the tv can be damaged by your lamp and then you really will have to get out the wallet. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Aug 03, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
