Question about Elna Sewing Machines
I had a Elna (7208378)1010 given to me but can't figure out how to thread it. Is there a diagram I can download? Thanks. Marie
  • 128 Answers
How do I sell problems
tension on an Elna L4 overlocker (or serger in USA) is controlled with the four dials on the front of the machine, an overlocker has a tension dial for each thread (usually 3, 4 or 5) and the mid range setting will be 5 on each dial. It is critical to lift the thread pole to its maximum height and follow the threading diagram correctly taking the thread from the cone, through the thread eyelets on the pole, then usually a thread carrier on top of the machine, down and around the tension dial, then usually through another couple of thread carriers until reaching the needle or loopers. Many overlockers will have a threading diagram inside the front looper cover and will use colour coding on the components so you can see where each thread goes.
Jun 02, 2014 | Elna Sewing Machines
How to thread a elna 654 overlocker
you can try youtube for a video
or sewusa they have some diagrams
or here is 2 links for a manual for the machine, one is a hardcopy
and the other is pdf downloadable copy
http://www.sewingpartsonline.com/instruction-manual-elna-654-download.aspx
http://www.sewingpartsonline.com/instruction-manual-elna-654.aspx
Feb 11, 2013 | Sewing Machines
How do you put a bobbin in a elna so i can use it to sew
Drop in a full bobbin with the holes side upwards (I'm assuming this is a Swiss Elna sewing Machine horizontal bobbin design as you haven't given the model number).
Now, hold the thread tail with your right hand and pulll the thread clockwise towards you while holding the bobbin still with a finger from your left hand. Bring the thread tail around towards you until it goes into the little slot, then press downwards onto the thread tail close to the bobbin until you hear it click into the tension spring. Test by lifting the thread tail upwards, it should stay in tension and not come back out of the groove.
Now close the back slide cover over the bobbin leaving the bobbin thread tail visible out to the right.
Now manually turn the flywheel towards you while holding the top thread tail and take the needle down into the bobbin holder area and back to the top, pull the thread tail to bring the bobbin thread up to the top.
There is a threading up diagrams at www.sewusa.com http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
for the old Supermatic but the bobbin holder design is almost identical for all the subsequent models such as the SU, TSP, Supermatic or Air Electronics like the Stella, Carina or Jubilee, the above is the same for all.
Sep 19, 2011 | Elna Sewing Machines
I have a Elna Air Electronic TSP machine and are looking for the manual. Type 58, no: x2414392. Where can i buy it and what is the cost? Regards, Anne-Marie Smit RSA
Hi Anne-Marie, I believe your TSP would look like this one below?
there is a manual available for download at www.diplodocs.com, just search with "Elna 58 tsp" and you should find it.
There is also a great website in the USA, www.whitesewingcenter.com where there is lots of Swiss Elna manuals, accessories and spare parts for sale, really great resource as Tavaro SA no longer operates and the current Elnas are made in Asia. They do sell O/S but you may need to pay by bank draft.
I trust that this helps you with your TSP, it was a well made machine.
Jul 20, 2011 | Elna Sewing Machines
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
I just inherited an Elna 2002 machine and I can't figure out where the thread goes on the machine. I've looked at pictures of the machine but there's not a holder on my machine for the spool. There are...
tally_girl_22.jpg You need to pull them up from the retractable position for storage and transport, many Elnas have the retractable thread spools like this to protect them from breakage.
Apr 27, 2011 | Elna 2007 Mechanical Sewing Machine
How to thread an Elna 2005
Hi. I've searched a number of my sources for a manual for your machine, but the closest I could find is for the 2002-2004-2006 models at http://www.mastersewusa.com/info_elna_2002_2004_2006.html
Threading should be similar enough between your machine and the ones covered in this manual that you can see what's going wrong.
Hope this helps!
Robbie
Jul 17, 2010 | Elna 2005 Mechanical Sewing Machine
How to thread bobbin on Elna SU
Please describe the type of bobbin you have. Is it held inside of a removable metal casing? Or is it a dropin type? Is the sewing machine what is known as a "freearm" which you can put a sleeve or trouserleg over or is it a flatbed type? When I know this I can help you further.(I used to sell sewing machines).
Jun 11, 2009 | Elna Sewing Machines
Sewing Machines Logo
240 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
