Question about Solis Maestro Electric Burr Grinder
Timer knob is broken, I need a replacement
Timer knob for my solis grinder is broken, I need a replacement
  • 1,089 Answers
Hi Contact Baratza at 877-701-2021 They should be able to help.
Posted on Feb 06, 2010
I have got a master 5000 and the brew unit gets jammedor locks when goes on brew mode.
Hi
There are a couple (3) of things that can cause this.
1. You have a broken brew drive but you would hear a clicking noise if this happens.
2. You have an over charge going into you brew unit. There is a small knob in your bean hopper. Turn it back 1 mark and try again.
3. Your grinder has come apart and is grinding very coarse. (French press size) New grinder.
Jun 01, 2011 | Solis Master 5000 Espresso Machine
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
My Solis Maestro grinds but produces only about
Hi
I would say that your grind adjustment ring is broken inside and needs to be replaced.
Contact Baratza at 877-701-2021 Mon. thru Fri. 8:00 to 5:00
Nov 14, 2009 | Coffee Makers & Espresso Machines
The grinder on my solis digital master 5000 winds but does not grind.
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jun 14, 2009 | Solis Master 5000 Espresso Machine
Stalled... won't grind... makes no sound... it is 5 years old...
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the grove and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
May 21, 2009 | Solis Maestro G385 Electric Burr Grinder
Maestro Burr coffee grinder stopped grinding
Hi
Remove bean hopper
Apr 04, 2009 | Solis Maestro G385 Electric Burr Grinder
Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Insert a screw driver into the **** and pry gently outward with a
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Switch Broke
I don't know about the switch going inside but you can contact baratza and they will send you a new knob that won't fall off for free.
Nov 25, 2008 | Baratza Maestro Plus (G385) Electric Burr...
The timer knob broke - can't find replacement
Assuming it has broken on the shaft then you could pry the broken bit off the shaft and take the knob and broken piece to your domestic appliance parts stockist. The shafts are usually a standard size and there might be a similar knob that you could replace it with.
Oct 02, 2007 | Solis Maestro Electric Burr Grinder
Solis Maestro Electric Burr Grinder Logo
273 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
