Printer has paper stuck. I can't see the small piece of paper. The printer will not work.
  • 163 Answers
I would suggest taking dismantling the printer, but check in manual for safer way of freeing the paper.
Hope this helps!
Posted on Feb 06, 2010
Printer not working paper was jammed but now out
Check for small piece of paper that might have been still stucked in the printer if not the disconnect the USB cable and restart your printer
Jul 20, 2014 | Epson Photo Office Equipment & Supplies
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
A warning sign has appeared on the printer, which says: 'Paper is jammed in the printer. Turn off the printer, open the scanner unit, and remove the paper. See your documention'. But There is no paper...
either a sensor broke
or
a small tiny piece of paper is stuck
after removing a jam if the paper tears a small piece of paper can cause the jam error message
Jan 19, 2011 | Office Equipment & Supplies
A small piece of paper is stuck but its not
Hello there This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 07, 2010 | Office Equipment & Supplies
Paper jam, removed paper but still says jammed. Is there any way to tell where the jam is or reset machine ?
You should be able to have a piece of paper feed all the way without hanging.
Most of the times, you can see a small piece of paper stuck in a corner.
I have used a cut piece of plastic ( from a file folder ) and worked small pieces out that way.
Good luck, Happy Holiday's
Nov 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
My ricoh CL 3500 keeps getting a Y paper jam.
There is something stuck in it. A small piece of paper, paper clip.
A friend of mine was having the same problem with a similar printer. I told him there was something in there. I took a look and found that a paper clip some how fell into the unit and was in a tight spot. Once removed the printer worked great.
It could be as simple as a little piece of paper, or a bit hard like a piece of paper wrapped around a moving part inside.
Nov 20, 2009 | Ricoh Aficio CL3500N Laser Printer
Had this for less than a year and now as it prints it sometimes jams and when it does work the printed image is crooked. Seems to be picking up the paper unevenly.
There is probably a crinkled piece of paper stuck in the paper path somewhere causing an alignment issue. Open all the access panels you can and check everywhere for a small piece of paper. Check really good as this issue can be caused by a VERY small piece all folded up.
Aug 08, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Message reads: the paper is jammed clear the paper and press OK
Even if a small piece of paper stuck inside the printer you ll get this msg.  So what you have to do is if you have a Air blower or vaccum cleaner blow air inside the printer,  If any piece of paper is stuck inside it will come out and you won't get that msg again.  Try this and sure it will work...!
Mar 18, 2009 | Office Equipment & Supplies
Showing paper jam but no paper in machine help!!!!
please confirm that all paper detecting switches are in normal position and can move freely and no small pieces of torn paper inside-clean all switches with dry cloths or brush.-reset your copier off-on-operation.
Jul 22, 2008 | Office Equipment & Supplies
Paper stuck
you have to open the printer and cleaned the pieces otherwise send it to some qualified professional for servicing
May 16, 2008 | Samsung CLP 300 Laser Printer
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
