Question about Sony Televison & Video
My tv is in stand by cant get it to anything - Sony Televison & Video
  • 4 more comments
  • Ruth Collins Feb 06, 2010
    The Model number is KP57WS520 When I power it wont do anything red light blinking no picture are anything still in stand-by
    Alright I have a 57" Sony TV model number is KP57WS520 It is in a stand-by mode ,a red light is blinking ,but cant power down are nothing no picture either.Im stuck in the house with % kids and we are having a blizzard HELP!!!
    Its blinking 9 times I did unplug it but didnt wait 10 mins. so I do it again
    Did you get my message its doing 9 blinks
    Ok thankyou
    Ok thankyou
  • 1,476 Answers
I understand you to be saying that your set is in standby mode and will not power on. Could you supply the model, brand etc. Also what if anything happens when you press the power button? Is the standby light blinking a code which could be helpful to localize the problem? Send me more information and we will see if we can get you an answer.
hardrocko
Posted on Feb 06, 2010
  • Kim Yearick
    Kim Yearick Feb 06, 2010
    Look at the blinking light and count the number of times that it blinks at about 1 sec apart. It should at some point pause for 3 seconds then start blinking again. Between the 3 sec pauses count the number of blinks and let me know what you get. Also have you unplugged the unit yet? If not unplug it for 10 minutes then plug in and try it. If it is just the micro with a problem this will reset it and it should work. If it doesn't work you have bigger problems. I need the blink count please.
    hardrocko
  • Kim Yearick
    Your problem is on the G board possibly D6116 and D6301. It could also be a panel module error or thermal error. Unless you are an electronic tech you are probably not going to be able to get it going today. If you are good with mechanics and tools you should be able to replace the board. Usually easier and cheaper than trying to repair the same. One of these sites should be able to supply the part www.encompass.com or www.partstore.com or www.shopjimmy.com Let me know if you need more help.
    hardrocko
Samsung le19r86bd television which is stuck in standby mode
Sounds as if it won't reboot. Apart from the obvious like turning the power off and waiting, I can't think of much else to do. Have you checked to see if anything is fractionally loose? Is it covered by warranty? If so go back to the manufacturer.
May 06, 2015 | Samsung Televison & Video
My tv lcd cant turn on
unplug wires from the power supply to the main board, if you still don't have 5V stand-by the power supply is bad. could be fuse, capacitors or anything in the 5V circuit.
Feb 18, 2014 | LG 42LC2D 42 in. LCD HDTV
We have a dyson vaccume and what ever makes it stand isnt working. I dont think we did anything wrong. But I cant make it stand.
the steel rod has come out of the groove that makes it go up/bown this video will show you.
Dec 08, 2012 | Dyson Vacuums
How do I use the green energy saving button on my remote. I cant get it to do anything
energy saving features are saving energy by consuming less power when tv is in stand-by. some tvs also adjust pictures brightness according to light of room thus saving energy. u will not see any change in picture quality.
Aug 25, 2011 | Televison & Video
I need 1 leg of a stand for a Philips BDL 4231 TV. One of our legs snapped when moving the tv and we don't want to wall mount it. \r\nThanks, AOM
Electronics stores do not stock extra stands for TVs. Each TV comes with one stand and that stand goes with the TV.
If you contact Philips directly you may be able to purchase a stand on it's own, but this isn't likely if your TV is over a few years old.
Check ebay and see if anything is available in your area, if not, you may be limited to purchasing a hybrid stand to mount on or wall mounting.
Mar 15, 2011 | Philips BDL4231C LCD TV
Technosonic lcd2017d stand lost
Hi I have a technosonic LCD3251 tv and am trying to take the stand off, as it is wall mounted now, i have taken all the screws out but i still cant get it off!! D you remember how you took yours off?
Jul 26, 2010 | Televison & Video
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Tv switching on from stand by
It could be not inputing any number on the timer. Or sometimes hitting the button many times until you get it to zero setting. Or sometimes, the cheat of not setting the time clock of the tv.
Apr 21, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Cant get scenium off stand by mode not manually ,remote useless
Is The nise a squealing. (bearing Noise) ? If so its probaly bad bearing in your color wheel
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
