Question about LG GSA-H55N DVD-RAM Burner
MY BIOS SETUP DOES NOT DETECT THE DVD DRIVE - LG GSA-H55N DVD-RAM Burner
  • 163 Answers
Try re-connecting it or re-installing it.
Hope this helps!
Posted on Feb 06, 2010
Why my intel motherboard Bios not detect my external ASUS SDRW DVD drive . Any help please ?
Disable Fast boot in bios setting...
To Disable Fast Boot:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Go to the Boot menu.
  3. Disable the Fast Boot setting.
  4. Press F10 to Save and Exit
Oct 16, 2013 | Intel Desktop Board D845GLAD Motherboard
DVD not on device manager or my computere
try to reset your bios setup to factory defaults then check if your dvd drive detect at bios setup
if doesn't detect your dvd drive , try to uplug it to your laptop . check your manual for info. to disassemble it. if doesn't work..maybe the problem is your dvd defect.
need to replace.
Dec 11, 2011 | Toshiba Satellite M45-S169 Notebook
I would like to install windows xp on the hp hdx9150. But Sata disks are not recognised. So i find a driver for that, i can give to the systeme with touh F6 , wind cd-rom windows xp bigin to install
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
Aug 05, 2011 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
Invalid configuration information-please run setup program. Performing automatic IDE configuration...... how to solve this problem.. tq..
Did you install a new hard drive, CD drive or DVD drive?
When a new drive is installed it needs to be configured in the BIOS. If so you need to go into the setup (BIOS) menu and then hold down the and keys and the press the and key to re detect newly installed IDE drives.
IDE (Integrated Drive Electronics) refers to the interface circuit that the motherbrd uses to communicate with your hard drive, CD drive or DVD drive.
Feb 17, 2011 | Dell Optiplex G240 (OPTIG240) PC Desktop
I have an msi ms-7390 k9n sli ver 2 motherboard and I updated the bios to the latest ver. 1.2. After that when cold booting the motherboard does not initialize usb you have to press delete to enter setup...
move the sata connection for your bootable HDD to another port like 3 or 4 and the bios will detect then run bios setup to boot from the sata 3 or 4 and it works like normal, must be a bug in sata 1 and 2. had same issue trying to install win7 x64. Win 7 refuses to detect sata DVD drive, moved it on the MB and it installed fine.
Jul 19, 2010 | MSI K8N Neo4-F Motherboard
Replaced bad drive. Doesn't find new drive when
When you start your laptop, press Del or F2 to enter BIOS Setup program. There adjust your BIOS Settings to detect your new hard disk. When detected, save the BIOS settings and exit BIOS Setup.
May 21, 2010 | Gateway MX6920 Notebook
RE-INSTALLATION PROBLEM
it doesn't seem to be cpu. have you tried to update bios? download usb bootable latest version of your bios and give it a shoot. if it does not help, try use external cd drive to reinstall os. press f9 at startup and choose usb hard drive. oh, one more thing-this may be memory corrupt, but not likely. test it in the bios.
Sep 09, 2009 | HP Compaq 6735s Notebook
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Dvd rom won't work
You forgot to check the jumper settings of the Hard Disk and the DVD Drive found at the back near the IDE and power cables. If you are using one IDE cable, then one jumper should be a Master, that's the Harddisk, and the DVD drive a Slave. If you are using two IDE cable then both must be Master.
You should check also the Harddisk jumper help settings printed on them, some harddisk needs the jumper settings for Slave presence on the same IDE cable.
If it doesn't work then It's either the cable or the DVD drive has a problem.
Oct 31, 2007 | Compaq Presario 5000 PC Desktop
LG GSA-H55N DVD-RAM Burner Logo
193 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
