Question about Centrios Televison & Video
I need wiring diagram for the 5.1 output What is sr sl l/fl r/fr
I used one wire at a time, listened out of what speaker they were playing.
Posted on Feb 07, 2010
How do I hook up the receiver to the subwoofer to the tv
Here's the Owner's manual -> https://docs.google.com/viewer?url=https%3A%2F%2Fwww.paradigm.com%2Fdownloads%2FOM-100.pdf.
There are many ways to connect the system depending on your receiver's outputs and the speakers. Usually, the TV L/R output connects to one of the receiver's inputs. The receiver's preamp sub output goes to the powered subwoofer. The receiver's FL/C/FR/SL/SR/RL/RR speaker outputs go to the respective speakers.
Mar 03, 2017 | Paradigm Audio Players & Recorders
Cannot get sound from center SL and SR speakers...FL and FR speakers and sub work fine...
find the menu on the reciver. there will be adjustments for each speaker. if not that. change it to a different sound setting like cinama,rock,surround,movie,ext. try each one differ setting use differ speakers
Feb 10, 2011 | Denon AVR-4800 Receiver
Need stereo wiring diagram for 2002 gmc jimmy
Hello! Constant +12=Orange...Switched +12=Yellow
Ground=Black...Illumination=Grey
FR + Green
FR - Black (common ground)
FL + White
FL - Black " "
RR + Dark Blue
RR - Internally grounded
RL + Brown
RL - Internally grounded
Guru.............saailer
Feb 19, 2010 | Car Audio & Video
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
I need the wiring diagram for a toshiba tx-904 compact disk player / receiver
red ignition w-fl speaker(+) w/b-fl speaker (-)
gray-fr speaker (+) gray/black -fr- speaker(-)
yellow-constant 12v(+)
blue motor antnna
rca gray-rear left - rca black rear right
black ground
Aug 22, 2009 | Toshiba Car Audio & Video
How to hook up protron pds-2315
First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
2. Connect the DVD Player to your television.
A. Video:
There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
B. Audio:
On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
Feb 21, 2009 | Protron PD-DVR100 DVD Recorder
Need color codes and wiring diagram for a 2003 Pioneer DEH-P6500
The wiring colors are the same on all major brands of head units it goes a following:
Red: swtiched +12
Yellow: constant +12
Black: ground
Orange/white: dimmer
Yellow/black: cell phone mute
Blue/white: amp turn-on
White:FL speaker +
White/black:FL speaker -
Gray: FR speaker +
Gray/black:FR speaker -
Green: RL speaker +
Green/black: RL speaker -
Violet: RR speaker +
Violet/black: RR speaker -
I hope I could help. Good luck
-Andrew Hawkins
Aug 20, 2008 | Pioneer Car Audio & Video
Out to speakers only in 5CH mode, or front L/R
set it on dolby digital mode not sterio mode should be differnt modes on a ch only use prologiic or spin the mode dial to doby digital on movie on direct tv wont be dobly fake suround more less but center should work change settings modes
Jan 26, 2008 | Denon AVR-2807 Receiver
JSI js5001 Home Theater
My dvd player won't go on. Worked one day the next day wouldn't work any help?
Jan 05, 2008 | Progressive Computer JSI 6 spkr. Home...
Televison & Video Logo
50 people viewed this question
Top Centrios Televison & Video Experts
Ron Oblinsky
Level 1 Expert
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Centrios Televison and Video Expert? Answer questions, earn points and help others
