The dryer high setting stopped putting out heat, now the medium setting isnt heating either
  • jshstyle Feb 06, 2010
    We are trying to test the elements and thermostate with a digital clamp meter. It says to set to RX1 but it doesnt have that setting, what do we do from here?
    President:
  • 2,468 Answers
I would first try the cycling switch,located on the element case that turns on and off the element for the various heat cycles you set,they can get erratic after time and cause either too hot or too cold cycling of the heating element, if not this component,then, i would check,if an electronically controlled dryer(i.e. keypad controlled) try opening up the rear panel by the control and check carefully the wiring and "flat-ribbon"cables that supply and send signals from the board(s) and check for cracks in these cables too,as they are subject to heat and can crack internally and become intermittent,as for all said,also, check the hi-limit switch, resettable switch, all on the element case for possible problems if the other item does not cure the issue
Posted on Feb 07, 2010
    Brigadier General:
  • 3,917 Answers
Since the dryer is not heating in any mode it is possible that your dryer isn't heating because its heating element is defective. Heating elements cannot be repaired. In your has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
For some testing help please check the bellow mentioned links:
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 06, 2010
How do I turn the heat eating down?
Need a make / model of the dryer your asking about. There are far to many out on the market. They work differently. But usually the settings are Regular is high heat easy care is medium heat. And delicates is a low setting for heat.And fluff is No heat.
Sep 30, 2014 | Dryers
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Dryer only heats on medium and high settings and the medium setting is very hot. Does not heat on low at all.
Sound to me like you need to check the vent for proper air flow. Make sure the pipe to the wall aint kinked. Take it apart and clean it up real good. My homemade crappy movie;
Feb 27, 2014 | Frigidaire FEQ1442ES Electric Dryer
Kennmore Elite HE4 no heat on low or extra-low setting
Assuming this is a gas dryer, it is likely the igniter has failed. The igniter plate has to heat up to glowing in order to heat up the thermocouple that turns on the gas valve.
Sep 03, 2012 | Kenmore Dryers
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Heating element and/or replacement bulb
no light bulbs on its own line and routs through the door switch as for the heat check your temp select button or your thermostst in the control panel should be a tech sheet with specs but be sure to put it back when your done
Feb 11, 2009 | Kenmore 63942 Dryer
Dryer Heats on High all the time
I don't think it is the heating elements. You have checked out all the important stuff. Is there power coming from the controls on medium and low. It sounds like this is the problem.
Jan 23, 2009 | Frigidaire FEQ332E Electric Dryer
Consequences of using high heat in dryer
the vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Dec 27, 2008 | Whirlpool GGQ8831L Gas Dryer
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
