Question about Nokia 2126 Cellular Phone
Got wet, appeared to be ok, then lost display
How can I replace the display?
  • trac2126 Feb 21, 2008
    Thank you. It helps to see that maybe I can install it myself! Unfortunately I didn't find a source for the replacement part so far either, when I looked. Can you recommend a source, and also elaborate just a little more on the specific screw? (My town used to have a known repair person but he has retired.)
  • 871 Answers
Hi there
open your celphone by using a specific screw and when you are able to open it, look for the lcd housing and manually remove it from the board.you can buy a replacement lcd and manually replace it and install it by yourself. always check if the rubber connector is correctly attached.
hope this helps.
Posted on Feb 21, 2008
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
I have replaced the imaging unit and it still asks for a new one how do i reset it
folow the steps please:
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
May 19, 2011 | Samsung CLX-3175FN Printer
My LG GM 200 mobile display got wet in rain .i kept that display completely dry. after i fixed that it is not working just appears white. tell me how to solve this problem?
my LG GM 200 mobile display got wet in rain .i kept that display completely dry. after i fixed that it is not working just appears white. tell me how to solve this problem?
Nov 24, 2010 | LG GM200 Cell Phone
How do I reset the printer to the english language panel display
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Nov 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
Model 917.272911 20hp twin cyclinder B and S eng. 42inch cut. From the front facing the engine, the left side is not working. I have changed the spark plug twice, switched the two ...
If the plug is wet that cylnder isn't firing. Use a compression gage to see if both cylnders are the same,you may not have enough compression on that cylnder. You may have lost valve clearance on that cylnder, its usually exhaust valve. A simple valve adjust ment will correct it.
Sep 29, 2010 | Craftsman Garden
I have a problem with my laptop: when i turn on
The video information to the LCD screen is lost. This can be a faulty video cable/connector or a faulty LCD screen.
The graphics card on the Acer is OK, that is why when you connect a LCD monitor to the video port on the Acer you see the normal Windows images.
Try re-seating the video cable connector on the motherboard.
If this doesn't fix your then the LCD screen is faulty.
Replacement screen are available on the Internet. Try this company for replacement screen.
www.lcdparts.net
May 25, 2010 | Computers & Internet
American Telecom cordless phone model RA22304H
This works for the PA22504H and I think your model works the same way.
Press OK key till HANDSET appears.
Press the arrow key till REGISTER appears.
Press OK key and PIN appears.
Press 0000.
Press OK and SEARCHING appears.
Hold the button on the base till green light comes on.
Dec 12, 2009 | Lands Phones
Maytag MDE7400AYW taking 2 or 3 cycles to dry
it's probably your sensor assembly. go to www.repairclinic.com/Appliance-Parts?s=t-MDE7400AY-%3d%3d&z=100 . That is the best possible solution and not too expensive. Good luck.
Apr 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Spinning but clothes are still very wet ,
unb means unbalanced i had the same problem and i called comet where i got it from and they replaced the chip board and ever since then its been fine i hope this helps you
Jan 27, 2009 | Haier XQG50-QF80 Front Load Washer
How do i reset my Pioneer SX 316 Surround Sound System. i lost the owners manual.
1. Switch the reciever into standby.
2. While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3. When you see RESET? appear in the display, press the ENTER button. OK shows in the display.
4. Press SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
Aug 08, 2008 | Pioneer Audio Players & Recorders
Nokia 2126 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
