Question about Maytag MFI2569VE Bottom Freezer French Door Refrigerator
Vegetable compartment freezes - Maytag MFI2569VE Bottom Freezer French Door Refrigerator
  • 4,793 Answers
Unit temp set too cold set to 2.
Posted on Feb 06, 2010
Vegetable compart freezes the vegetables
You probably have your compartment set to meat and not produce. Adjust the setting on the tray, or get the food further away from the air return ducts.
Jan 23, 2012 | Kenmore Side by Side Refrigerator
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Vegetables and salad materials icing in vegetable compartment
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 29, 2011 | Westinghouse Refrigerators
Fridge is freezing in the lower part of the fridge...vegetable and meat compartments
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
Jun 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator compartment freezing
Experience tells me the design should maintain 40 -34 degrees in the refrigerator section when the freezer is between 0 and -10 You might check this if you have a thermometer for the job, and adjust the thermostat accordingly. Your unit may also have an airflow control (I didn't research) to adjust the refrigerator independent of the freezer.
May 25, 2009 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerator model NoGC20C7C3Ewith fridge setting just on and freezer setting low following defrosting the operation seams ok but deteriorates with ice forming on the rear freezer panel and the lower...
Defrost system problem. Could be in heaters, defrost thermostat, or defrost timing circuit. Freezing in vegetable section is due to air back flow related to frozen evaporator coil in freezer compartment.
Colder air settles and warmer air raises.
Ice maker problem is separate. Bar up engages micro switch that is supposed to shut it off. Bad micro-switch?
May 27, 2008 | Maytag Refrigerators
Maytag MFI2569VE Bottom Freezer French Door Refrigerator Logo
99 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
