Question about Coleman Powermate Premium Plus 6250W Portable Generator
Adding new motor to generator
I can not get the generator lose frome the motor.i have taking all the bolts lose and it will not come off.how do i get it off?
  • steve brown Feb 06, 2010
    model# pmo544208
    President:
  • 2,030 Answers
Send me your model number and ill look at the parts diagram.
Most of those units there is a long bolt that goes thru the generator rotr and holds the rotor onto the end of the engine shaft.
Posted on Feb 06, 2010
How do i separate the motor from the rest of the unit onan weldanpower 125
Take off the end cover on the generator. There is a bolt that goes thru the shaft that bolts to the engine Once that's out then the remaining bolts on the housing come out to seperate the generator from the engine.
Jun 07, 2014 | Electrical Supplies
How to remove and replace the stator from a champion generator
You don't state what model you have. I just replaced the rotor on a Champion Model 41302 but removing the stator is the same process.
You will need to remove the muffler and muffler outer protection. Remove the bolts that hold the muffler outer protection. Remove the two bolts that hold muffler to the engine exhaust.
Take a block of wood and place it under the engine to support the generator. The supports on the generator head end will be removed so the generator will tip down and make it difficult to remove the stator.
Remove the generator end cover by removing two bolts.
Remove the two bolts that hold the muffler to the end cover.0834b898-460f-41f6-b0a0-6704ae605277.jpg
Remove the bolt that holds the ground from the generator to the frame.
Remove the two bolts that hold the end cover supports to the rubber supports to the frame.
Disconnect the quick connect electrical connectors and remove the 120/240 volt wiring from the terminal block. See second picture below.
Remove the ground from generator to wiring cable assembly by removing the bolt that connects it to the end cover. Yellow and green wire in picture above.
Remove the bolt from DC brush assembly and pull out of generator. Picture below shows assembly removed.
The stator and cover now can be removed from the generator. Take a rubber mallet to tap on the back of the brackets on the end cover to loosen it. The rotor bearing is seated in the end cover making it hard to remove by pulling by hand. Once lose pull straight out.
The stator can now be removed from the generator end by taking the four bolts out.
The installation process is the reverse.
Nov 27, 2013 | Electrical Supplies
Service manual
Take the through bolt out of the end of the alternator / rotor shaft. it is a long bolt. The shaft from the engine is tapered and unlikely to just pop off. Find a bolt that will screw into the end of the rotor shaft (hardend) find a metal bar that will slide into the rotor long enough so the bolt tightens down on the bar, it will pop the alternator off the tapered shaft
Oct 10, 2013 | Coleman Powermate Powermate 5000W...
Guys I am in the position to buy a Homelite Generator 1100watt 4 stroke its a shelf demo, but the noise decible seems to be a bit load at 93, my 2 stroke is only 91 my main concern is will this be nioisy...
The difference between 91 & 93 dB is negligible. If the genset is a good deal, take it, and then look to improve the dB dampening. Most all gensets can have additional silencing added to them. Even bolt-on systems are often threaded beneath the gasket surface allowing for improvements. Either way, you are probably OK, and will not notice a significant difference in dBs. Also, it may be possible to mount the generator in such a manner as to have the exhaust facing away from your caravan, reducing the noise even further. Isolating the generator frame from the drawbar will also significantly reduce the transmitted noise. You may need to give this additional thought; motor mounts for auto engines strike me as a possibility.
Best regards, --W/D--
May 03, 2011 | Vacuums
Disconneting generator from motor. PM54A4302 Coleman generator. I do not know how to disconnect the generator from the motor, I would like to know how to release the motor from the generator.
I am assuming that you have removed the end bell with field winding (long bolts that extend from outside of generator into mount bolted to engine) and the only obstacle is the rotor on the crank of the engine. I am also assuming that you were able to remove the long bolt thru rotor into crank. Now you will need to apply penetrating oil to the shaft of the engine to loosen the rust on the taper (tapered shaft fits very tightly into core of rotor). It may take several applications. Place a piece of hardwood against metal to protect the rotor and firmly rap with hammer on both sides. You may need to use pry bar against engine and rotor as you hammer hardwood. Repeat as necessary, some rotors will be very stuck due to rust. Good luck.
Oct 05, 2010 | Coleman Electrical Supplies
How do I remove the case from the generator on a B & S motor / power boss 030249? the gov. is fried.
take the end case off the end of geny 3 x 10mm bolts?
on the end of the geny shaft is a 10mm bolt wip it out,
the geny is held to the motor by 3 or 4 bolts wip them out too,
then with a sharp rap on the geny case near the motor end the geny should pop off the taper its held on to the engine crank shaft,,,there tight as well!
Jun 26, 2010 | Briggs & Stratton Power Products 5,550...
I need to change my alternator but where it is located is a problem. so what is the easiest way to change an alternator for a 1998 chrysler sebring?
GENERATOR - 2.5L
REMOVAL
Disconnect battery negative cable from remote negative terminal on shock tower.
Unplug field circuit from generator.
Remove the B+ terminal nut and wire Wiring Connections - 2.4/2.5L
Loosen top mounting ear bolt.
Loosen pivot bolt, but do not remove. Be careful not to lose nut Generator - 2.5L Engine
Loosen adjusting bolt on idler to allow removal of the generator drive belt.
Remove pivot bolt, do not drop spacer.
Remove top mounting ear bolt.
Remove upper generator bracket.
Remove generator.
INSTALLATION
For installation, reverse above procedures. Tighten all fasteners and add small amount of lock tight.
Good luck and hope this helps.
Jun 24, 2009 | 1998 Chrysler Sebring
How to Replace Dryer Motor
make sure its unplugged,pull over the pulley to losen belt,unplug electrical connector from motor,take any bolts and nuts lose.remove motor.install new motor in opposite of removal.
May 15, 2009 | Frigidaire Dryers
Oil change
There are two 14mm bolts on both sides (lower) of the motor. Unscrew one or both and drain the oil....Replace with sae 30 or 10w30 oil and should take almost a quart. (Put the bolts back in and tork slightly.) Check oil level.
Jan 11, 2009 | Pramac Storm 5000 Watt Generator
Motor is locked up and I need to change motors
you have too take the accessory cover of the engine to access the bolts that hold the generator to the engine
Jan 05, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
107 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
