Question about Siemens WFXD5200UC Front Load Washer
Door Switch Er:04
Thank you very much for your help, I recently had the door gasket replaced by a service company, I complained after the repair was complete that the door was not in alignment and it had to be physically lifted up to close the door. . Is it possible that this miss alignment caused the door control to fail. I made an error in my model number it is WFXD5201UC , Thank you for all your help
  • 770 Answers
Yes there is a tab that goes into the lock mech. and the misalignment will cause damage to the latch assby
Posted on Mar 03, 2008
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
LG WF-T700 Troubleeshooting DE blinking
The "DE" code indicates a door open error. This can be caused by the door not closing all the way (this could be because of bent door/hinges or the door gasket bunching up and not permitting the door to close properly), loose electrical connections at the door switch or powerboard assembly, or the door switch itself is faulty. It can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity would mean a bad switch. Also check the door gasket for "bunching" and you can unplug and reseat electrical connections. These are some areas to look at. Be sure to disconnect unit from power before attempting any repair/troubleshooting. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 28, 2009 | LG WFT1071TP Top Load Washer
04 crysler voyager lx automatic door not working
Could be either , you may have a fuse blown(check first) ,but as it was only partialy opening before suggests that it will probably be a motor issue .If you have 12v at the door motor when pushing the switch then you need to replace/repair the motor.Come back to me if you require further assistance.
Please leave fair comment if you feel I have helped you.
Thank you
Aug 23, 2009 | 2004 Chrysler Voyager
Refrigerator Door Gasket Has Split
I FIND IT VERY STRANGE THAT THE ENTIRE DOOR NEEDS TO BE REPLACED IN THE EVENT THAT THE RUBBER IS FAULTY.I NO FOR A FACT THAT SOME SAMSUNG FRIDGE RUBBERS ARE QUITE HARD TO REPLACE AND THE QUICKEST SOLUTION FOR THE TECH IS TO REPLACE THE ENTIRE DOOR.TO ESTABLISH IF THE RUBBER IS REPLACABLE I SUGGEST YOU LIFT THE GASKET IN ONE CORNER AND LOOK FOR A GROOVE OR SCREWS.SOME RUBBERS ARE BASED ON A PUSH IN PULL OUT BASIS.IF YOU FIND IT HARD TO ESTABLISH WHICH IT IS I THINK ITS BEST YOU ASK SAMSUNG TO SEND YOU A MORE ADVANCED TECH TO ASSIST YOU IN THAT REGARD.ALSO YOU CAN VISIT SAMSUNG WEBSITE AND FIND A TECH NEAR YOU.
GOODLUCK.
MOHAMED
Sep 19, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Water will not drain
yes this will casue the pin to break off you most likly need to replace the latch assby
Feb 17, 2008 | Washing Machines
Siemens WFXD5200UC Front Load Washer Logo
427 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
