Question about Toshiba 55HX70 55" Rear Projection Television
Toshiba 55H70 My unit powers on, then goes to standby. Replaced convergence chips 6 months ago, also re-soldered the area around Z801 high voltage protect ic. Worked great until two days ago. Started to notice image bowing in on the top and bottom, then convergence began to get bad. Image dropped out within 5 minutes after that. Has not powered up correctly since. I have removed the convergence cables as noted by some techs to see if that is a problem again, but it still won't power up. I see nor smell anything burnt on the circuit boards.
  • 4 more comments
  • gmarkthornto Feb 06, 2010
    I removed the digital converter board and the two convergence ic's. The unit still goes into the slow blink power light mode after about 20 seconds of power-on.
    I just finished re-soldering the connections to Z801 and the tv powered on and the screen came up. As expected the convergence is all messed up. The image was stable for a few seconds then I heard some clicking noise that coincided with the screen jumping. I shut down the unit, and reflowed solder on the components near Z801 and tried again. The unit came up and remained stable for 30 seconds before I powered it off. How long can it run safely without the convergence chips?
    This is similar to the problem I had after the last time I replaced the convergence chips. I had some sort of problem in the power section that caused the entire image to jump, then the unit would power down. I fixed it by working in the area around the high voltage/x-ray protect chip. I never really saw anything bad but it worked for 6 months. An I missing something obvious?
    Thanks
  • gmarkthornto Feb 07, 2010
    I have reinstalled the convergence chips and the board. The tv is up and running now. The alignment needs to be adjusted again, but the biggest issue is horizontal jiggle. What I mean is the horizontal width is fluctuating slightly. Obviously there are some solder problems I keep coming across. I am using de-soldering braid to remove solder, then re-soldering with lead-free solder.
    What voltages should I measure, and how should I measure them to look for problems? It looks like I have some sort of fluctuation that is causing the horizontal deflection to jiggle. Six months ago I went through with a capacitor checker and couldn't find any bad caps, and there are no visible leaks.
    You mentioned replacing the caps in the convergence circuit. Which ones would those be? The ones on the main board, the digital converter board or the hyper board?
  • gmarkthornto Feb 08, 2010
    Yesterday before the game I had a very bad revelation. I was in the local Radio Shack getting more de-soldering braid and looked at the solder. While the bins were labeled as containing lead-free solder, that had stocked the standard solder across all bins. I have been re-soldering with standard solder. Needless to say, I am a bit **********. I am going to an electronics supply in San Antonio today to get new solder, then I am going to start working through the board as you suggest. From my latest work, I am back to the situation where the set goes into the standby mode rather than powering up correctly. It definitely looks like a solder problem because I wasn't moving the board between the time I the unit working, but with horizontal stability issues, and now with it not powering up again.
    When you talk about replacing the caps, how far should I go down that road? Do I start with the big ones, or should I make a list from the schematic and order them all up?
    I replaced with 110's from ACME sales. They appear to be fine. I removed them and the digital convergence board with no change. It appears I have some problems on the power board with solder joints and possibly caps. I re-soldered the area around the high-voltage protect circuit and got the system to power on, but the horizontal hold was jumpy. I continued re-soldering suspect looking connections and now the unit is back in the mode of going directly to standby.
  • 1,476 Answers
It could be that this time the convergence module went. I have replaced many convergence ICs and don't believe I have ever had any go out within 6 months. That does not mean that they can't. Remove the leads from the convergence area to isolate the ICs as you said you were told. Now remove the digital convergence board which should be nearby and probably will be in a metal box for noise protection. If you can I would unsolder the convergence ICs to totally take them out of the circuit and just in case one or both shorted out. Once everything I talked about has be removed try the unit. If your problem is in the convergence only your set should work but have an ugly picture. Let me know what you find and we will go from there.
hardrocko
Posted on Feb 06, 2010
Testimonial: "Thank you, I resoldered thoard withe entire power b lead free solder and the image is rock solid. "
  • 3 more comments
  • Kim Yearick
    Kim Yearick Feb 07, 2010
    The unit can run forever without the convergence circuitry, it will just not be a pretty picture. I am intrigued by your statement about z801 and resoldering. Ever since they removed lead from solder I have seen more bad solder connection problems than ever before. Perhaps you need to go back to the components which you soldered before and clean them thoroughly and use lead free solder to resolder the units. It is possible that some capacitors in the convergence circuit have gone south. They are so cheap I would just replace them all. Try these suggestions and get back to me.
    hardrocko
  • Kim Yearick
    You also mention a problem in the power supply section. I think it's time to measure the voltages and be absolutely sure that they are correct. Let me know.
    hardrocko
  • Kim Yearick
    Just reread your post. Perhaps we are missing something obvious. You mention doing some rework in the power supply. Check or redo that also and use lead free solder. Let me know.
    hardrocko
  • Kim Yearick
    Kim Yearick Feb 08, 2010
    That would be the electrolytic capacitors on all the boards which you mentioned. I believe you are on the right track and need to just keep resoldering until your unit is fine. I've had sets that the very last solder connection, in the worst possible position to get to, was the final problem. Make sure that somehow you don't miss any connections. One other possibility could be a cracked board, crack to small to see, from all the work that has been going on. If that is the problem your only solution would probably be a new board. If you resolder the connections and change out the electrolytics and your unit still does not work correctly you may have to consider a board change. Also make sure you solder any connectors where they go through the board. Another possible problem could be the connectors. Typically they are inserted into the female end and crimped. I remember once having to actually solder the wires to the connector because they were not making connection through the crimp. Let me know how this works out.
    hardrocko
  • Kim Yearick
    I just reread your comments and something struck me. Usually when the horizontal width flucuates it is caused by a problem in the horizontal circuit. I would concentrate on that area.
    hardrocko
  • Toshiba Master
  • 5,138 Answers
Unpluging convergence does not work on all TVs just some of them like Magnavox, also what STKs did you replace old ones with If you went back with 110s that is your problem again use 180s. STK392-110s are the worst ICs they made they fall apart and DO NOT hold up. Did you resolder all of your yoke plugins? Mats Electronics is where I order ics
1-800-628-1118
Posted on Feb 07, 2010
My tv keeps shutting off. it works fine for a couple of days and at times it only goes back on when i keep plugging it into the power outlet.
Toshiba 55H70 55" Take the back off and pull the HV power board and check all the solder joints, seem to me that you has a cold solder joint. check it out be carefull with high voltages.
Jan 27, 2011 | Toshiba 55H70 55" Rear Projection...
The picture on my Toshiba 55H70 is distorted. Most of the screen is fine, but the bottom left looks bent with all three colors misaligned. I tried adjusting the convergence some but it did nothing for that...
hello am rico, you need to replace your convergence ics (stk392 or 393 something esle). check for caps,fuses, resistors, cold solder in the boards. if you need more help, feel free to call at anytime. 602-810-7149.
Jan 07, 2011 | Toshiba 55H70 55" Rear Projection...
Convergence problem w/55h70. red is ok but can't fix blue. Is there a component or board that is easily replaced?
Yes,U have some basic machanicals skills?The Toshiba Tv convergence board,it call a Hyper board.Try website Ebay.com to buy a refurbish board.This board no longer produced by Toshiba,if can't find it.The Convergence 2 STK ICS,and some or all it resistors,must replaced manually.Must have tools,and knowing how to do basic soldering,to do this.
Apr 06, 2010 | Toshiba 55H70 55" Rear Projection...
Replaced a convergance chip..(ps8003) now tv
hello Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board
regards
shaun
Feb 24, 2010 | Sony KP-46WT500 46" Rear Projection...
Toshiba TP48C90 Convergence (replaced ICs, worked for 2 days)
Well, my thought is that there are a ton of knock off generic convergence IC's out there that usually hold up as long as yours did. Professionals like me will only use Sanyo original STK's. The counterfeit STK's out there are everywhere. Do some research on the web to locate Sanyo originals, they are out there.
Jun 11, 2009 | Toshiba Televison & Video
I have a sony projection tv and the red is coming out of line where it makes you see double like a red rainbow effect shadow. I tried the flash focus and the problem still persists any ideas on where to go...
When you first turn it on,Count the flashes on the standby/power button.
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground,or held high), IK video path is defective.
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This isalso a problem in the power supply circuit, check T603 and R672.
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.Check IC1509, Q1505
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on
the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback
transformer), or the associative components in the high voltage circuits are defective on the D board.
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times
you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors
are bad, check R8051 and IC8005, also on the "D" board
Please rate this solution
Jan 03, 2009 | Sony KP-53V80 53" Rear Projection...
Do you know if they sell vibration eliminators or shock absorbers for the rear projection floor tv?
Solder connections to the convergence stk ic chips have developed ring cracks most likely. The chips will fail if not resoldered. The chips will be mounted to large heat sinks and have stk392-110 or similar marked on them. You will need good soldering skills or professional help is in order. The chips are prone to failure for this reason. Unplug the AC cord before attemping to open the TV . You will need to gain access to the bottom of the circuit board the chips are mount to. Unplug the electricity...did I mention to unplug the AC three times??? Yes ;)
Jan 14, 2008 | Toshiba 55H70 55" Rear Projection...
Very wierd Toshiba video problem
Hello techman2429m, It looks like you may have a color convergence problem. when you dropped the TV the convergence/purity rings on the neck of the tube may have shifted or by changing parts you may have thrown off the convergence. I would suggest using a pattern generator and adjusting convergence also adjusting the purity settings. This I believe will clear up your problems.
Sep 17, 2007 | Televison & Video
Projection TV convergence problem
Get it fixed, because this is a simple repair. One of your convergence IC's has burned out and needs to be replaced. A good tech can fix the set in-house in about an hour and a half, and I charge $150 when I fix a set like that but shops in your area will vary so ask around. If you have a satellite receiver or a cable box, the changeover in 2009 should not affect you.
Sep 04, 2007 | Toshiba 55H70 55" Rear Projection...
No picture
57H81 57 in. Rear Projection Television Go to above unit for tip on your problem.
Jun 22, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 55HX70 55" Rear Projection Television Logo
462 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
