Not spinning..although drum turning and draining as normal.. Thanks
  • 104 Answers
Could be a imbalance with the load inside the machine if there is too much or too little clothes in. Had this the other week on a machine when owner had only put a couple of items in, when the items were wet the were heavy on one side of the drum and the load sensors stopped the machine from spinning up. Remove clothes from machine and try empty, if it works properly either throw some more stuff in to help even the weight or remove some stuff if overloaded.
Posted on Feb 07, 2010
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
Maytag model LA- 510 washer. Not spinning fast enough, Clothes come out too wet and water sometimes left in bottom of drum. Belts were changed. No help. Also, machine makes a large ''clunk'' sound at end...
the cluncking sound is not a brake system since there are no brakes, but the stabilizer of the drum. as when it stops turning the whole weight of the drum 'hangs' on the stabilizers. That might also be the problem with not spinning fast enough, although I think that its not spinning fast enough because there's too much water inside. I would check the drain hose and drain filter, either one of these two are clogged up, and therefor not letting the water out.
hope you'll find the problem soon.
friendly greetings............Gilbert.
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Oct 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
