Question about Philips Magnavox MWR10D6 DVD Recorder
Dvd 10d6 one touch timer recording
I gave up on trying to set the clock and can't get the one touch timer recorder to work, can someone help me to get the one touch working?I did everything the manul said over and over.Thank you.
    Problem Solver:
  • 9 Answers
MAGNAVOX DVD RECORDER MODEL # MWR10D6: Is a piece of junk. Yet another worthless waste material and rescources. In other words they or someone else could have taken the materials and energy used to assymble this thing and used it for some other appliance or device that would actually work. This thing is so worthless that it was environmentally irresponsible for the manufactures to even make it. Now all it's good for is filling landfills.
My suggestion is to do as I am right now and go onto any and every forum, or message board you know about and warn as many people as you can away from this piece of junk and the SCAM that is being perpatrated by Magnavox and whoever else helped them cook up this scam.
I've even made space for a photo of it and description of how sorry it works on both my myspace.com and facebook.com pages.
Posted on Feb 23, 2008
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
Timer Recording
This is from the KR10 manual. Hope it helps.
1. Set the clock before setting a timer.
2. Insert a recordable disc with enough space.
Then:
1. Press [TIMER PROG] on the remote
2. Use up/down arrows to select "New Program" then press [ENTER]
3.Use up/down arrows to enter the date, then press right arrow
4. Use the arrow keys to enter the start and end time, then press right arrow key.
5. Use the up/down arrows to select the external input position to which your cable/satellite box is connected, then press [right arrow]
6. Use the up/down arrows to select a recording mode.
7. Press [ENTER] when all items are entered.
8. Press red [I/O ON STANDBY] to set a timer programming.
DO NOT FORGET THIS LAST STEP! The timers will not work if the recorder is not in standby mode.
Jul 24, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Ilo DVDR 05
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e Someone said these were similar. Try the red/yellow/white cables. select that SOURCE. first select your recording length. I usually put mine on 3-4 hours and try to keep it from running to the end or you have problems. I use Rewriteable dvds, if you use reg discs be sure to finalize the disc so it will work in other players. I read if you are copying macrovision vhs to use the antenna input and it will copy it with that input. Just tune it to channel 4 or whatever. Forget trying to set the timer to record from tv. I never have success with that.
Jun 19, 2008 | iLO DVDR05 DVD Recorder
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
LG DR275 timer recording problem
I found the answer to the problem eventually,it was because when setting up the recorder I had set the clock to 2007 instead of 2008 everything now working OK
Mar 07, 2008 | Televison & Video
WHEN I RECORD A DVD IN MY MWR 10D6 DVD RECORDER IT IS NOT ABLE TO BE PLAYED IN MY OTHER DVD PLAYER WHICH IS A TOSHIBA. WHEN YOU PUT THE DVD IN IT ALWAYS SAYS PLEASE CHECK DISK. THIS ONLY HAPPENS WITH DVD'S...
When you burn your DVD the disc has to go thru a FINALIISATION process before it can be used on other DVD players. Sounds like either your recorder hasn't run the finalisation or it doesnt do one, in which case your DVD's wont work on another player. Check thru your menu's for a FINALISATION option and make sure you run it.
Marty.
Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Will not play
does the player turn on? it might be a display setting on your tv- meaning it has to be on a set channel or mode to work
Dec 27, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Record
i have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
menu
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
trin
Nov 16, 2007 | Sylvania SRD3900 DVD Player/VCR
Programmed recording to the hard drive
Either You haven't set the time/timer correctly or you need to find a way to clear/format the hard disk.
Aug 16, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Philips Magnavox MWR10D6 DVD Recorder Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
