Question about Frigidaire FTF530FS Front Load Washer
Our front load washer was in storage for several months. We just hooked it up, but there is no water coming to the machine. We have double checked the supply itself and that is fine. Is there a switch or fuse in the machine that we should check
  • RMK9 Feb 06, 2010
    None of these issues was present. We had checked the water supply carefully already. However, in desperation we took the cover off the top of the machine and found that the water selection switch had come loose. We made sure it was sitting properly and the problem is gone. Thanks for the help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First check
to see if the water flows adequately from the other faucets in the home; wait for service to be restored. Avoid running water in other areas of the home when doing laundry. Fully open supply faucets to washer. Also try to straighten the hoses. Also, the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
Frigidaire gltf1670as0 uses to much water. Washing machine pulls water in and then pushes it right back out. All cycles are working but our water bill doubles each month we use it.
I would double check the drain hose, it sounds as if you are siphoning as it fills. The drain hose must be higher then the washer itself to prevent this from happening. If this does not solve this issue, get back to me and we can would on another possible solution.
Thanks, Gere
Oct 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
No water run into the machine, kenmore front load washer
Is water turned on to machine don't laugh it has happened.
Check water valve if you know electricity you can hook 110 volts directly to the water valve and see if water will come out or check with an ohm meter.
Also be sure you have 110 volts to machine check first.
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
Water not coming into my HE5 washer
Check that there is water coming from water supply, if not lines can be clogged or frozen.
If water is coming to the machine, but not entering into the drum, then it is a faulty inlet valve, or a faulty control, have parts tested and replaced.
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Suds in the floor...
are you using he detergent,,,or low suddsing detergent,,,i believe your putting to much detergent,,and not the right detergent,,,to test run a load with no soap,,and see if you get water on the floor..onthejob
Dec 29, 2008 | GE WBVH6240F Front Load Washer
Leaking from the front
take a butter knife and release the two clips on the top of the front panel (look in the seem between the top and front panel and push the butter knife directly into the clips), this will release the front panel from the machine. then you can see where the water is coming from.
May 14, 2008 | GE WHRE5260E Top Load Washer
Frigidaire affinity front loader washer
The E-70 code means your hot and cold water hoses are hooked up backwards. Double check that your hoses are hooked up correctly.
Aug 31, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
