Question about Logitech X-530 Computer Speakers
Hi, i am only getting sound out of my sub and 2 other speakers, i have connected the black jack to the sound jack on my macbook, i would like to know if there was a way i could connect the green and brown jacks to my macbook. thanks
  • 316 Answers
Hello my friend,as i know there is not laptop with 5.1 audio card on-board so the only think to get your speakers work fully functional is to buy one external usb audio card
Posted on Feb 06, 2010
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Sub doesnt put out a sound
go into your sound properties and make sure your sub is turned on or not muted there should be a seperate one for sub just like you have one for speakers
May 26, 2009 | KEF Audio KHT 1005 System
Subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Nov 10, 2008 | JVC SPPWA670 Subwoofer
Hi, I bought a teac dvd and 5 speaker surround sound system yesterday. I am having trouble setting it up. I want to run the TV sound through it as well, but at the moment it is only going through the sub...
Whoa,ok.Sounds like things aren't connected properly.The first step is to disconnect the TV and concentrate on getting sound from a dvd or cd.Read the owners manual and double check that the speakers are hooked up correctly and that the unit is in the correct surround mode.Next, connect the TV.Use an RCA cable to go from an "Audio out" jack on the TV to an input jack on the Teac -e.g. "Aux, TV, etc.If your TV doesn't have the proper jack, I'm afraid you're out of luck.
Jul 21, 2008 | Teac Audio Players & Recorders
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
Computer and Speakers
HERE is a link to the Z-540 manual. It should help. Connect the green plug from the audio input cable to the "line out" jack on your TV. Do NOT use the black or orange plugs. WIth a 2 channel card like your TV's you will not get sound from the rear speakers unless you enable matrix mode through the remote.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 05, 2008 | Logitech X-540 Multimedia Surround Sound...
No sound from subwoofer
have you checked for the continuity of the wirings? check for the resistance of your speaker from it jack..... it should measure close to 8ohms or 4ohms using a digital multimeter (DMM). check also the sub out jack of your reciever if there is a signal from it using your main speakers if they come with jacks also (turn the volume low to prevent damage to other speakers you connect on it!
Nov 07, 2007 | Tannoy Sensys 7 Speaker
Logitech X-530 Computer Speakers Logo
316 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
