Rf tech 433 mhz
I can't get the thing to show the outside temperature. everything else works, at least i think it works so far.
  • 13 more comments
  • Weeksclan Mar 29, 2008
    same problem even in frezzer shows outside temp 71 degrees? Love the clock whe this worked.
  • Anonymous Mar 30, 2008
    After change batteries, the ourdoor sensor does not report temperature. Could not find product manual.
  • srvan May 02, 2008
    re: RF-tech 433 MHz
    I can get the temperature display to detect the outside remote sensor. I have reinstalled the batteries and have tried the hold/seek but it does not seem to work. thanks.
  • rskeen May 14, 2008
    Can not get the clock to display the outdoor temperature. It alway shows 153.2 F for outside. It did work for awhile but then went back to the 153.2 F temperature. This temp. does change during the night ,going down a few degrees
  • Anonymous May 23, 2008
    I can't seem to find a website or any info about this product. My inside temp works ok and I can set the clock, other than that, I am lost and the alarm is set to go off at 5 am and 12am. awesome timing right? Can someone please help me before i throw it away?
  • Anonymous Sep 05, 2008
    I have the same problem but my sending unit has 2 AAA batteries and the unit that shows temp has 2 AA batteries. I still tried holding the gray button down and that didn't help.
  • ibtv1 Nov 29, 2008
    my unit does the same thing,no outdoor temprature.
  • rzwahlen Dec 06, 2008
    can not get the outside to read nor can I move the settings alread there; how do I do it? Richard
    how do you change the C to f on the temp settings?
  • gemscut4u Dec 26, 2008
    unit stopped displaying outside temp. new batteries - reset no help
  • wr3rd Jan 13, 2009
    Can't get the outside temp to show
  • Anonymous Jan 16, 2009
    instructions manual of 217s34
  • helppansy Jan 30, 2009
    I can't get the outside temp what I'm gettig is the temp inside a few degree's different then the inside . Can you help me ?
    Pansy
  • bobbalouis Mar 26, 2009
    After 2 or 3 years of working properly I now cannot get an outdoor temperature to register. I've tried every possible combination of battery in/out reset on/off etc. I've tried brand new batteries and still no connecting signal. It seems like the outdoor transmitter is broken.
    Is this likely and can it be replaced? I probably have to buy a complete new system?
    Thanks for any assistance!
  • reginald adams Oct 28, 2011
    need replcement 433 mhz outdoor temp sensor
I had the same problem and finally found my manual. Here's what to do, everyone!
1. Take back panel off the sending unit, where the three batteries are, by unscrewing the 4 phillips head screws (assuming you, like I, had put the screws back in after installing new batteries). You will see a little gray button in a hole above where the batteries are; the little button is one you can push down with the same phillips screwdriver you took the 4 screws out with - don't do this yet.
2. Now, hold down the "channel" button on front of receiver panel for 2 sec, until the dash in the "ch" box and the place where the temp is supposed to be starts blinking.
3. Now, while these indicia are blinking on the panel, push the little gray button down and hold it for 2 seconds. This causes the transmitter to "register" with the receiver. You should now see a 1 in the "ch" box and get a temp reading.
4. Put screws back on, put receiver where you want it, proceed with rest of your life.
Posted on Jun 06, 2008
  • Sue Wollensak Jul 08, 2013
    This was very helpful, Do you know how to change the time and date?
If your batteries die, or for some other reason you have to sync your remote with your indoor station, do this:
Once you have new batteries installed -
  1. On the indoor Weather Center press the "Channel" button - you should see the "out" channel display blink
  2. On the remote sensor, press the reset button (it's inside the battery cover on mine) for about two seconds
  3. When you release the reset button, your main Weather Center should beep when it makes the connection
  4. Viola! You've done it!
For setting other things, such as the time, press "mode" until the upper left section blinks. Then adjust up or down by using the + or - buttons on the back. Once you get that section set where you want it, press the "mode" button again to move to the next section.
I also posted this on my blog at: http://stevelindhorst.com/2008/12/rf-tech-433-mhz-weather-centre-reset/
Posted on Dec 11, 2008
  • 4 Answers
If you have the Living Solutions atomic projection clock with remote temperature unit (many sold by Costco), your outdoor reading will eventually start showing a dotted line instead of the temp. Yes, you may need to replace the AAA batteries in the remote unit, but if that doesn't work, you also need to replace the AA batteries in the back of the main clock/display unit! Next, press the reset button next to the AA battery compartment, then press the reset button next to the AAA battery compartment on the remote unit, wait for the atomic clock to set the correct time, etc. and you are good to go. Unless your atomic clock doesn't find its satellites (mine never does) in which case you need to set the time manually. Start by holding down the smaller "AL" button on top of the unit until display flashes, use that button to proceed to next item, use top two side buttons to go up or down for time, year, month, date. All of the above just worked for me!
Posted on Aug 27, 2009
Here is what you can do.
1. inser batteries into both the remote and receiving (main) device. until you saw the digits in both displays.
2. Hold "-" key at the back of receiveing device, then you will slash flash in the "out" textfield. This state shows that receiving device is ready to receive the signal from remote device
3. press the reset button on the back of the remote device,it may take more one time. So you can press 2-3 times until you see the outdoor temperature in the main menu.
That's it. Have fun.
Posted on Jul 01, 2009
  • yunlongkth Jul 01, 2009
    here is what you can do.
I HAVE A SCAN OF THE MANUAL IF NEEDED
THOLGATE@POWERGATE.CA
Posted on Dec 22, 2008
I found that if you take the batterys out of both units, then put the batterys in the outside sending unit first (dont push reset) then put the batterys in the main unit. it worked for me ! good luck!
I need a new temperature probe for my RF-tech 433 MHz 683F03 weather station. Can you help me. The probe on the end of the wire broke off. Thanks, Dan
Posted on Jan 13, 2009
Do we have *.pdf manual for this device? I hav a son who was able to set up an alar, damn...
Posted on Jul 24, 2008
What help me was to start the reset button on the main unit and then to install the batteries on the the outdoor one while it was scanning. When I just pressed the rest button of the outdoor unit as bsq2bbb wrote it didn't work. Hope it will work for you.
Posted on Oct 26, 2008
I have some similar devices, not sure about the type/code of the receiving unit (front only says RF-tech 433 MHz), but the back of the sensors says: Ewig Industries co ltd / Model 217S34 / 3VDC.
I have two receivers and two sensors, and the idea is to connect both sensors to each receiver so that I can read all temps at all receivers.
I lost my manual long ago, but here's what works for me when changing the batteries:
- remove all batteries
- insert batteries into receiver units
- after a few seconds, insert batteries into first sensor (-> ch 1)
- after first sensor has connected (beep from receiver(s)), insert batteries into second sensor (-> ch 2)
See also: http://www.wrightclick.com/weather/RF-TECH-683F03-weather-station-manual.pdf
(identical sensors but slightly different receivers)
Posted on Oct 08, 2008
  • Guest Oct 24, 2011
    This is pretty much the best way - what I found worked was to leave both units for a few minutes after removing the old batteries to allow everything to reset to default conditions. Then add one battery to tx unit, then both batteries to receiver and quickly add the second battery to the tx. Works every time - don't touch the reset buttons!
  • merlenbaugh
    merlenbaugh Oct 06, 2012
    Tried all the solutions ... none worked messing with the reset button ... but this solution from guest195 worked perfectly !! thanks
If channel button does not work, press and hold "-" button on the back.
Posted on Jul 02, 2008
  • Bigrichinwa Nov 18, 2010
    I found how to set the date time and switch between F and C.
    1. Hold the set button for 2 seconds. hit set until what you want to set is blinking.
    2. Use the set button on the back to advance the time, date, or change the C to F.
    a. The degree measurement is hard to notice the C or F will blink and is the last one
    to be set.
ACCU-TEMP WEATHER STATION, MODEL IW007A. IS THERE A MANUAL FOR THIS DEVICE?
Let's find out. Google (ACCU-TEMP)(IW007A)(manual) without parens.
Oct 27, 2016 | Measuring Tools & Sensors
I have already try putting in new batteries and taken out of the clock and the trasmitter and still dont work what can i do now its a SioScan Temperature Transmitter 433 MHz
This type of device requires battery installation in the transmitter first, then a brief wait for the transmitter to begin sending temperature data. Once the transmitter begis sending data, install batteries in the "receiver" and check for temperature display.
Nov 01, 2014 | Home
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. taylor.norman1@gmail.
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
Aug 21, 2013 | La Crosse Technology La Crosse C86234...
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
Aug 26, 2010 | Mitsubishi Heating & Cooling
Lost Rf tech 433 mhz weather centre's outdoor sensor
I have a RF-tech 433 MHz transmitter for sale, $25.00 includes shipping.
huppertsr@juno.com
Jan 06, 2009 | Computers & Internet
RF-Tech 433 MHz Problem
I have the instruction manual, send me a mail: lundberg53@gmail.com
Nov 01, 2008 | Computers & Internet
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Computers & Internet Logo
30,140 people viewed this question
David Payne
David Payne
