Question about Frigidaire ATF6000ES Front Load Washer
I pulled off the front seal to clean it an a round mental coil came off. how do i put it back?
  • 56 Answers
Place the rubber boot back on the lip first then slowly and evenly pull the spring back around, this may take a couple of tries
Posted on Feb 06, 2010
Do i need to clean coils?
you dont new unit are sealed, some have a filter in front at the bottom vent.
Sep 23, 2012 | Maytag MSD2651 HE Side by Side...
Cleaning & Maintenance
From general experience (I'm 55) : Depends on where the heat transfer coils are; on the back or the bottom or both. If on the Back: should be cleaned with a brush & vacuum at least every 3-6 months. If on the bottom, about every 2-6 months. Bottom coils can usually be accessed from the front by opening the door/ removing drawers and pulling off an access cover. Bottom coils also usually have a Fan that can get clogged with dust/ mice(Yes! Mice.) that hurts the performance also. May have to pull it out and remove a back cover. For the rest, Check the condition of the door seals and replace any that are not completely closing. Keep the seal surfaces and the insides clean. Defrost regularly (every1 to 2 months) to prevent ice buildup. Some units also have interior fans, that are supposed to function when the unit is attemting to cool.
Mar 25, 2012 | Samsung RF265AA Bottom Freezer French Door...
One side of my bunn ultra 2 slushie machine is leaking how do you change a bad seal to stop this problem?
remove the bowls by pushing in black button on the bottom front left of the bowl, pull the bowl up a little, then pull it forward and off. pull the auger off and the seal is opaque, cup shaped, and on the shaft. replace that, lube the edge with food safe lubricant (i.e. superlube), lube the large round bowl seal in the back and put it all back together. you may need a preventive maintenance kit installed as well, but that's a bit more involved
Sep 28, 2011 | Bunn Margarita Machine Ultra 2 Slush...
My Bosch washing machine is leaving sludge like marks on my clothes. Ran the machine at 90 degrees with soap but no load. Didn't solve the problem. Any ideas?
Make sure the draw is 100% clean inside the draw compartment to if the draw is all clean next thing to cheak is the rubber door seal make sure it is clean all the way round next thing to cheak is the pump at the front of the machine pull down the cover and undo the the pump cover by tuning anti clock wise water will come out when you cheaked it is 100%clean put it back together if you get stuck read manual if all toughs things are clean or bean cleaned. do a 90 again with washer cleaning detergent with you can buy at the super market hope this helped.
Aug 26, 2009 | Bosch Classixx WFO 2466 Front Load Washer
FRONT DOOR OF WASHER LEAKING
Hello. W/D here.
It's actually pretty easy to get it back on when you know the trick.
Since it has leaked on you, you may want to remove the seal off of the rim closest to the door and clean the rim and the sealing surface. The seal has a molded lip that fits on to a raised formed rim, and it gets pressed on snugly before the ring and spring are added. You can seat the seal by pressing on it all the way around with the palms of your hands.
To install the ring:
Start the ring 180 degrees from the spring, placing it in the groove behind the seal face. (You want to make sure that the seal is pressed back into place first). Work the ring on around the seal, until you get to mostly just the spring remaining. Now lever the spring over the lip and into the groove, using a small screwdriver, being careful not to damage the seal with the screwdriver.
Best regards, --W/D--
Aug 20, 2009 | Maytag EPIC MFW9700S Front Load Washer
My transmission is leaking..plz help!
If it isn't leaking from the Input seal, (The seal where the torque converter shaft goes into), then I suggest it's leaking from the Front Pump seal. Torque converter removed, look at the large round object, that has bolts going around it, and a shaft coming out the middle. The Input seal is in the middle. The large round object is the Front Pump. There is a large rubber O-ring that goes around the Front Pump. This O-ring can deteriorate, and leak. It can also blow out partially, due to inner damage of a spring clutch.
One thing I would like to advise you on. The Inner seal installation.
You should use the proper tool to remove it. You should use a seal puller. Also, when using a seal puller, the seal puller head can dig into the Front Pump cast iron case.
This can create a gouge, in the recess where the outside of the seal sits. This will create an area to leak.
Use caution when removing an Inner seal, and only have the seal puller head just far enough in, that it catches about half, of the inner seal -> metal outer ring. Past the rubber part of the seal, past the spring, and onto the metal outer ring of the seal itself. But, not far enough that the seal puller head will touch the Front Pump case recess.
If you did gouge the recess of the Front Pump case, clean the area with a clean shop rag. Use a half round file, and carefully remove the burr that the gouge creates. When a gouge is created, it upsets the metal. The gouge makes a 'valley', and a burr is created on the top edges of this 'valley'. That burr needs to be filed down to the rounded recess surface. Follow up with sandpaper. Wipe it out with a clean shop rag. Wrap a clean shop rag around the shaft, so that no metal fillings can get inside the Front Pump, and blow that recess out with air. Wipe the recess area again, with a clean shop rag.
To install an Inner seal, lightly coat the outside metal ring of the seal, with silicone. I use high temp Red. Failure to do this may cause a leak. Do this if you have a gouge or not. If you have a gouge, put a little extra silicone in that gouge, and fill it up. Don't use too much, but make sure the gouge is filled.
Either use a seal installation tool, or fabricate one out of Schedule 80 pipe, and have one end milled flat, and the corners rounded a little. The pipe must be large enough to fit against the flat outer lip of the seal.
Put the seal in place. Push on it, try to keep it flat and even. Put the seal installation tool on the seal. Tap on one side of the installation tool, then tap on the other, until you get a good start. Good start being the seal starts to go in, and is even all the way around. Then take you hammer, and tap around the outside edge of the installation tool. Go around and around. Watch how the seal is going in. If it starts to tilt off to one side, stop. Remove the seal. Start over. It must go in even all the way around, as it's being installed.
Failure to keep it even as it's installed, will twist the seal, and the seal's spring will pop out. Now you have a twisted seal, and no spring. The seal is junk!
BE SURE, to apply a thin light coat of transmission fluid, to the inner part of the seal. The area where the torque converter shaft will spin in. FAILURE to do this, might cause the torque converter shaft to twist, the inner rubber part of the seal, and twist the seal in half. The seal is then junk!
Apr 24, 2009 | 1994 Mitsubishi Mirage
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
How do you replace the door seal on a Bosch Nexxt front load washer?
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
How to replace rubber door seal
when you open the door you find a this wire clamp round the edge of the door seal, this just comes off with little force, this has to go back on obviously so don't bend it, the door seal just folds back on itself, the clamp on the drum end is often a large thin spring, and that also just pulls off, the seal then also comes away with a little pull, the new seal is fitted with the groove either side of the drum lip, then the spring is put back, take note how all is removed before working on it? the front of the seal is fitted then the wire, close the door to check a tight but easy fit, check for any leaks and correct fitting before leaving machine unattended any time, sound worse that what it actually is, if i have helped rate me,
Sep 16, 2007 | Bosch WFR 145 Front Load Washer
Hotpoint washing machine WMA66
Thank you gittos73.
It's as gittos says. When you open the door and look inside, at the very top of the door is a white square. This holds the metal clip. If you push the little white dot in the middle of this clamp gently, it gives way and you will see the round metal clip that goes all the way round the door rubber (gasket). Remove this and you can put your fingers round the gasket and pull it toward you.
Then take the lid off the machine and you will see a 6mm nut with a spring behind it and a wire clip similar to the front one, going round the gasket where it attaches to the drum. This has a crosspoint (phillips type) head on it and you can get a small screwdriver into it and undo it all the way. Then slide the gasket off and it will come away.
Fitting it is the reverse but it is a little bit tricky as you have to get the gasket behind the lip to make the seal. Take your time and they will both go round properly.
Aug 03, 2007 | Hotpoint WMA66 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
168 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
