Question about Philips Televison & Video
Magnavox tv mod# rj8550ak03 need part # for horiz output transformer on the defection panel a10338c003,also where can I buy it ?
  • Rommel Cana
    Rommel Cana May 11, 2010
    if it is the flyback find /look for the part number labeled on it, will try to look for replacement , and possibly post the chassis number of the unit. so other experts ( guru especially ) may try to help.
  • Rommel Cana
    here is a tip for you flyback which one of the two are you referring? transistor or flyback transformer?
2 Suggested Answers
  • 476 Answers
SOURCE: Magnavox model# RJ8550AK03 I need the part# for
I believe the part number for that is 003620020003 , but I believe it is a NLA item. Your best bet is to get the complete module off of another used tv, or contact the repair module companies like PTS electronics or tristate module to check their stock, they might have a rebuilt or a leftover transformer, who knows, try ebay, there is all sorts of things for sale over there. Good luck!
Posted on Feb 07, 2010
Magnavox model# RJ8550AK03 I need the part# for the horizontal output transformer located onthe defection panel.It is not a fly back more like low voltage supply .Where can I buy one?
Feb 06, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have two Sony KV-27FS120, they have the same problem, 4 blink, both have no vertical & horizontal drive from IC001 jungle chip, and Q505 horiz output blow. Circuits between them look good. I replace...
Check very carefully for cold solders on horiz. drive transformer also replace the electrolytic cap that shapes the horiz. drive signal - if you have a scope and manual compare the drive signal shape.
Some times using poor after market horiz o/p's also causes the problem - does the o/p heatsink get to hot to touch or does the horiz o/p blow immeadiatly?
Oct 19, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Tv wont turn on and has a high pitched sound while plugged in
your flyback transformer and driver circuit are operating, but the horiz. output transistor that needs to be in circuit w/horiz output transformer is open and can't amplify the signal needed for the flyback xfmr
Oct 09, 2009 | Televison & Video
How do I repair my television. It is a rear
sounds like your horiz output transformer is shorting out
Oct 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture goes into horizontal lines while watching then you shut it off for 10 min. or so and it resets it self
solder connections in horiz.drive/output circuit.also solder the flyback transformer.if only 10 minutes you need to solder in the
horiz.circuit area.get a magnify glass and usually will see hair line cracks around the
components.
Jul 17, 2009 | RCA TruFlat 27F520T 27" TV
TV went out
You need to replace the flyback transformer and horiz output transistor - I did mine for under $30 in parts....
Jul 28, 2008 | RCA F36650 36" TV
Rca flat scren hd tv
Examine horiz circuit with magnifier.....look for bad solder
connection.............check power supply area and solder pins of
horiz output transformer.............T.
Mar 19, 2008 | RCA 32F531T 32" TV
Horz. Output Transformer for a GE Mod#46GW945
Check this guys: //http://www.electronica-usa.com/
This guys may carry that part: //http://www.globalsemi.com/search.aspx
Jan 24, 2008 | GE 46GW945 46" Rear Projection Television
TV won't turn on...
Probable bad flyback transformer or shorted cap in horiz circuit,
horiz output xistor suspect,also...................have tech check or
replace set....................T.
Dec 03, 2007 | RCA 32F530T 32" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
