Question about Nikon Coolpix 4100 Digital Camera
Nikon coolpix 4100
My 4100 freezes when you insert a memory card! with no card in all appears fine but the minute I put in a card in everything stops working including the ability to turn the camera off.
  • bammers98 Feb 21, 2008
    Its 128. The camera has been fine for the last year!!
    Thanks anyway.
  • Max J Power Feb 26, 2008
    I have the same problem, same camera. I have tried SD cards of varying sizes (256, 128 and 512MB). Same problem with all. Worked fine for a month on a 512MB card. Have reset to manuf original change. Is there a way to re-flash the internal ROM on the cam to remedy this?
  • 1,027 Answers
I've heard the camera "STALLS" when any sd card larger than 256 is installed, how big is your card?
Posted on Feb 21, 2008
When do i need a new memory card for my nikon coolpix s4100
When you find it is too small for the number of photos you want to take, then you may want a larger capacity memory card.
Mar 28, 2013 | Nikon Coolpix 4100 Digital Camera
Nikon coolpix copy button will not work
Make sure the SD card is not set to protect with the small slide switch on the side of the card, then try formatting the SD card NOT the internal memory.
Jan 27, 2013 | Nikon Coolpix 4100 Digital Camera
How do I delete the pictures from my Nikon coolpix880 camera
Use this option to format the internal memory or memory card. Formatting the Internal Memory To format the internal memory, remove the memory card from the camera. The [Format memory] option appears in the setup menu.
Formatting the Memory Card
When the memory card is inserted in the camera, the [Format card] option appears in the setup menu.
or for more detail get the user manual from here
do rate the solution if helped
Nov 28, 2010 | Nikon COOLPIX L12 Digital Camera
I have pictures on the memory of my camera and I can't figure out how to get them to the card. When I scroll the menu to copy it will not allow me to select this option. I aslo don't understand why these...
To have pictures in the memory of your computer you have either taken photos without a memory card installed or accidentally copied them to your camera's memory.
To copy them to your memory card, you need to have the memory card inserted. Put the camera in view mode, press menu, select copy and select the first option.
Sep 24, 2010 | Nikon Coolpix 4100 Digital Camera
Mi Nikon coolpix 4100 shows often the message " write protected " how can I delete write protected?
It sounds as though it's your memory card that's locked.Remove it and slide the little lever on the left hand side of the card so that it isn't in the lock position.
May 01, 2010 | Nikon Coolpix 4100 Digital Camera
How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Aug 09, 2009 | Nikon Coolpix 4100 Digital Camera
Put 4GB card in - OUT OF MEMORY appears.
I have nikon coolpix L5, i just brought a 4gb memory card that's supposed to be compatible, but when i go to take a picture it say You cannot use this card?
Jul 11, 2009 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 4100 - transfer pictures to memory card
The easiest way is to transfer pics from the camera memory to you pc/notebook memory and then copy them to the the memory card thereafter with the help of a memory card reader.
May 15, 2009 | Nikon Coolpix 4100 Digital Camera
Error message: file contains no image data
I may be able to add some advice on how to solve this unfortunate problem of "file contains no image data". I have been suffering from the same problem. I have recently been on some amazing vacations and the photos I have lost due to this problem have been invaluable to me! I would pay an insane amount of money to get these photos back, but unfortunately I cannot!
I have a nikon coolpix camera. I contacted the nikon coolpix technical support center. I spoke with a representative who asked me what type of memory card I have. As it turns out I have a generic memory card, which is not compatable with nikon. The only memory cards brands that are indicated to be used with the nikon coolpix camera that I have are as follows: Toshiba, Panasonic, Lexmark, and Sandisk. Those are the only 4!
I was told that if you use another memory card besides the memory cards brands that I have listed... that the camera may communicate incorrectly with your memory card, which results in data that is incomplete to support an image. When this happens you will only see a portion of your image, and you cannot get it back. These bad images with incomplete saved information are called "corrupt files". The representative told me that there are some programs that are available to purchase that may be able to correct corrupt .jpg files, but she believes that they are memory card brand specific.
To put it simply, when you do not have to compatable memory card in your camera, it is as if your camera is speaking english and your memory card is speaking chinese and they are not communicating properly (this was the way the representative explained this problem to me). So check your user manual for your specific type of camera or look it up online to see what type or brand of memory card you should be using! I truly hope this helps someone avoid losing invaluable photos!
Nov 29, 2008 | Nikon COOLPIX L18 Digital Camera
Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 4100 Digital Camera Logo
115 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
