Question about Toshiba NB205-N311/W Netbook
I've installed a couple of programs and get a "regedit" error to "update". How do I update the regedit?
  • 316 Answers
Hello,my friend regedit is system registry editor.The message you received says that your program was unable to be installed because regedit failed to update (manipulate/edit) the system registry.So find out which program u have installed is not working properly,uninstalled it and the next time you want to install it try right click and run as administrator.
Posted on Feb 06, 2010
Mss32.dll missing on my pc
There are several different ways that mss32.dll errors can show up on your computer. Here are some of the more common ways that you might see mss32.dll errors:
  • "Mss32.dll Not Found"
  • "This application failed to start because mss32.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\mss32.dll"
  • "The file mss32.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: mss32.dll. Please install [APPLICATION] again."
Mss32.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the mss32.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Mss32.dll Errors Mss32.dll errors are caused by situations that lead to the removal or corruption of the mss32.dll file.
In some cases, mss32.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Mss32.dll Errors Important: Do not download mss32.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of mss32.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the mss32.dll error.
  1. Restore mss32.dll from the Recycle Bin: The easiest possible cause of a "missing" mss32.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted mss32.dll but you've already emptied the Recycle Bin, you may be able to recover mss32.dll with a free file recovery program.
    Important:Recovering a deleted copy of mss32.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system: Some mss32.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the mss32.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes: If you suspect that the mss32.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the mss32.dll file: If the mss32.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the mss32.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to mss32.dll. If, for example, you're receiving a "The file mss32.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The mss32.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version: if mss32.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command: to replace a missing or corrupt copy of the mss32.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates: Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The mss32.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive: I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause mss32.dll errors as they fail.
    Note: If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows: If the individual mss32.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair mss32.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid mss32.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows: A clean install of Windows will erase everything from thehard driveand install a fresh copy of Windows. If none of the steps above correct the mss32.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the mss32.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any mss32.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To The mss32.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 7, Windows Vista, Windows XP, and Windows 2000.
Still Having Mss32.dll Issues? Let a community of computer support enthusiasts help out! Post the details of your mss32.dll issue in the PC Support Forum. Be sure to let us know the exact mss32.dll error message that you're seeing and what steps, if any, you've already taken to fix the problem.
May 28, 2012 | MSI 645 Combo-L Motherboard
Sensapi.dll error
How to Fix Sensapi.dll ErrorsImportant: Do not download sensapi.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of sensapi.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the sensapi.dll error.
  1. Restore sensapi.dll from the Recycle Bin. The easiest possible cause of a "missing" sensapi.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted sensapi.dll but you've already emptied the Recycle Bin, you may be able to recover sensapi.dll with a free file recovery program.
    Important: Recovering a deleted copy of sensapi.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some sensapi.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the sensapi.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the sensapi.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the sensapi.dll file. If the sensapi.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the sensapi.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to sensapi.dll. If, for example, you're receiving a "The file sensapi.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The sensapi.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if sensapi.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the sensapi.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The sensapi.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause sensapi.dll errors as they fail.
  10. Repair your installation of Windows. If the individual sensapi.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair sensapi.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid sensapi.dll registry entries that might be causing the DLL error.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the sensapi.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the sensapi.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any sensapi.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The sensapi.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 7, Windows Vista, Windows XP, and Windows 2000.
Feb 11, 2012 | HP Pavilion Dv9910us Notebook PC
Theres A Problem of My Computer How To Fix MY Computer The Eror Name is iertutil.dll Thats My Problem Eror
Iertutil.dll Error MessagesThere are several different ways that iertutil.dll errors can show up on your computer. Here are some of the more common ways that you might see iertutil.dll errors:
  • "Iertutil.dll Not Found"
  • "This application failed to start because iertutil.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\iertutil.dll"
  • "The file iertutil.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: iertutil.dll. Please install [APPLICATION] again."
Iertutil.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the iertutil.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Iertutil.dll ErrorsIertutil.dll errors are caused by situations that lead to the removal or corruption of the iertutil DLL file.
In some cases, iertutil.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Iertutil.dll ErrorsImportant: Do not download iertutil.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of iertutil.dll, it's best to obtain it from its original, legitimate source.Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the iertutil.dll error.
  1. Restore iertutil.dll from the Recycle Bin. The easiest possible cause of a "missing" iertutil.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted iertutil.dll but you've already emptied the Recycle Bin, you may be able to recover iertutil.dll with a free file recovery program.
    Important: Recovering a deleted copy of iertutil.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some iertutil.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the iertutil.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the iertutil.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the iertutil.dll file. If the iertutil.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the iertutil.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to iertutil.dll. If, for example, you're receiving a "The file iertutil.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The iertutil.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if iertutil.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the iertutil.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The iertutil.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause iertutil.dll errors as they fail.
  10. Repair your installation of Windows. If the individual iertutil.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair iertutil.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid iertutil.dll registry entries that might be causing the DLL error.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the iertutil.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the iertutil.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any iertutil.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Any doubts you can contact a technician through the website
www.thebestpcdoctor.com
Toll Free: 877 407 8229
Aug 11, 2011 | Microsoft Windows 7 Ultimate for PC
My computer keep showing dciman32.dll
That is some corrupt files in action. Reinstall your Operating System (Windows) or install a new one (Linux). Make sure to back up any files that you have before reinstalling, as files will not be preserved during the process.
May 04, 2011 | Computers & Internet
Cant log in yahoo messenger due to error socialview plug in
Uninstall everything yahoo related from add/remove programs. Go to your C:, then Program Files and delete the yahoo folder from there also. Now go download ccleaner from www.download.com and run the cleaner, once that is done run the registry cleaner a couple times.
Try re-installing the latest yahoo from there. IF that failed also, you have one last shot that will work but it can be tedious a bit and a little dangerous so make sure to back up your files before proceeding. If the error still happens, do all of the above except for re-installing the yahoo. Now from the run command (Windows Logo Key + R), type: regedit <Hit ENTER>. Up top click on Edit and then click Find. Type: Yahoo! <Hit Enter>. Delete what it found and then press F3 to find the next yahoo! item. Delete everything it finds till there are no more matches found. Close the Regedit and reboot the pc. Now re-install the latest Yahoo Messenger and the problem is gone. I have done this several times for clients and this fixes it 100% of the time. Cheers!
Oct 26, 2010 | Yahoo Messenger
Having a problem with uninstalling MS office 2003 Error 1402
go to start.programs.run. type regedit in box. hit enter.
find HKEY_LOCAL_MACHINES. SOFTWARE.scroll down to microsoft office.delete.
DO NOT CONFUSE with microsoft windows or any other microsoft program.regedit is a volitile area you can mess up your os by deleting the wrong thing.
after this go to computer. cdrive program files and find microsoft office folder and delete. reboot pc when done.
good luck
Jan 10, 2010 | Microsoft Office 2003 Pro (269-07387) for...
Error 1920 installing Mcafee 8.5
Good morning! If you receive a "1920" error regarding failure to start a McAfee Service when trying to update or install Mcafee VirusScan, follow the instructions below.
WARNING: This procedure involves editing the Windows Registry. Using Registry Editor incorrectly can cause serious, system-wide problems that may require you to re-install Windows to correct them. Use this tool at your own risk.
Solution
  1. Uninstall McAfee VirusScan Enterprise using the "Add/Remove Programs" option in the Control Panel.
  2. If present, delete c:\Program Files\Network Associates and c:\Program Files\Common Files\Network Associates
  3. Go to the Start menu, select Run, and type regedit .
  4. Find and delete the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Network Associates.
  5. Restart the computer.
  6. Install McAfee VirusScan Enterprise and update the software.
Best regards
May 07, 2009 | Computers & Internet
How can i uninstall panasonic videocam suite?
I had this problem and someone pointed me towards this
http://www.appdeploy.com/software/detail.asp?id=178735
I eventually deleted the folder that this string identified, and I was able to re-install the software at long last
pipster
Jan 03, 2009 | Panasonic PV-GS500 Camcorder
A box come to install updates and when i push the install and it say installing updates but when it finishes it says some updates could be not be installed security updates for window XP then it shows...
One last thing :
turn off any ad-removal programs, Web accelerators, anti-spyware, and antivirus programs before you try to access the Microsoft Update site. These programs can cause script errors. Be sure to turn them back on once you’ve finished your update.
Mar 06, 2008 | Computers & Internet
Microsoft autoroute
Hello Sir / Madam,
1.If you are using Microsoft Windows XP or an earlier version, click Start, click Run, type regedit, and then click OK.
If you are using WindowsVista, click Start clip_image001.jpg, type regedit in the Start Search box, and then click Regedit in the Programs list.2.Delete the following subkeys from the registry:
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanner.1
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanResult
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanResult.1
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanResults10
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanResults10.1
Note Make sure that you delete every registry key because you will receive a different error message every time that you install the program.3.Install the program that you want.
Jan 04, 2008 | Computers & Internet
Toshiba NB205-N311/W Netbook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
