Question about Microsoft Computers & Internet
Xp proffesional. i have accidently erased wrong file.windows will not start ,says please install---system32hal.dll.how can i do this? problem is on my other computor,thanks
    Brigadier General:
  • 3,917 Answers
One possible fix. So far, this has been traced to an incorrect BOOT.INI file. To gain access to the Boot.ini:
Go to Start/Run and type in: msconfig. Then go to the Boot.ini Tab. Or...Right click the My Computer icon/Properties/
Advanced/Startup and Recovery/Settings/System Startup/Edit.
How to Edit the BOOT.INI File in Windows XP
http://support.microsoft.com/support/kb/articles/Q289/0/22.asp
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 06, 2010
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Please help! Corrupt system32/hal.dll file
just buy xp disk and reinstall the window...
Nov 02, 2009 | Sony VAIO Z1VA Notebook
Missing dll file.system32\hal.dll
For that first you have to fix error on harddisk.
Boot computer with recovery disk then choose recovery console mode.
Then type in prompt "chkdsk /r"
then press "y"
then it fix error on harddisk then install windows.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Microsoft Windows XP Professional
the problem is in the boot.ini
you need to insert the XP installation CD and start the recover console.
Type the following commands:
del C:boot.ini
bootcfg /rebuild fixboot
if you can't delete the file just try this command before:
attrib -H -R -S C:boot.ini
Jul 10, 2009 | Computers & Internet
then there is no option go get it back.... u have to boot into the Windows XP Setup then only u can solve this error...better get a CD Drive from any of ur neighbours or better buy one...
Jul 08, 2009 | Microsoft Windows XP Media Centre 2005 for...
Without cd rom how shld i install system32hal.dll file..
Install the file using USB drive such as pendrive.
Visit the below link for more information on hal.dll missing or corrupt:
http://support.microsoft.com/kb/314477
Try the steps in method 1.
For method 2, we need to use Windows XP CD, try to use external DVD drive and after connecting the external drive, you can reinstall the file or follow the other steps to resolve the issue.
Jun 25, 2009 | Acer Aspire One PC Notebook
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
if you have a windows cd you can do a system restore from it or at the boot screen some computers have a system recovery so you can use system restore without a disk, if you can use system restore, restore your computer to a earlier time and that should solve your problem
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
18 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
