Question about Kenmore HE2 Plus Front Load Washer
Washer (Sears front-load Mod. 110.A4757) bought in 2007 as a backup, installed in Dec. 2009, still new, now refuses to spin. No sound, no apparent reason. How do I get it going again ?
  • 2 more comments
  • treborsia Feb 07, 2010
    yes I can turn the drum by hand
    yes I can spin the drum by hand
  • treborsia Feb 08, 2010
    The water will not drain by gravity. Right now I can't get to the rear panel because the washer and dryer are top mounted so to heavy. Also the washer is filled with water so to heavy. And I can't open the door to empty it because the door is locked.
    I am getting a 5D code followed by an F- code (indicating an electrical problem according to the Sears book).
  • treborsia Feb 10, 2010
    Washer working. Had to call a service man. Couldn't get it working after checking all you mentionned. The service man found a small half-inch objet somewhere in the drain tube (or pump), checked the entire machine (an electric problem code kept coming up,..) and left me a 150 CAN$ bill. Can't say we didn't try ...THANKS anyway
  • 3,741 Answers
It doesn't drains or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 08, 2010
    President:
  • 1,185 Answers
Please check the following
Does the water pump out if not then lay the drain hose down into a bucket so that it does (The timer needs to be told that there is little or no water left inside the machine before it will do a spin cycle)
If the pump is working
Take the back off and look for the pressure switch it looks like a small flying saucer will be near the top of the machine, It will be connected to the bottom of the outer container via a small plastic or rubber tube.
Take the tube off at the lower end and blow into the pipe the pressure switch should click as you blow and then again when you remove the pressure.
If it clicks ok, try doing a spin on its own if that does not work you need to check the motor brushes to see if they are sticking.
If the brushes are free you are back to the main programmer
Posted on Feb 07, 2010
  • 15,935 Answers
Can you spin the drum by hand?
Posted on Feb 06, 2010
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
Kenmore Mod 110 24632300 won't drain
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110+24632300
and you'll see a list of major sub-components with diagrams and parts.
I'm assuming that it will spin.
See the section for the Pump, Motor and gearcase and the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Feb 13, 2010 | Kenmore Washing Machines
Kenmore front load washer: 4172952990. Does not spin. Clicks... at the beginning of a cycle it will spin for a few slow spins, then nothing. Had the Sears technician in. Said that it was the Speed...
Our kenmmore front loader is having a problem with the pump. When it empties there is dirt with the water. Is there any way I can get at the pump and clean it? It is working 70% and as long as I have the drain hose on the ground the water will drain. When I shake the hose dirt comes out and sometimes it says F21. Can anyone help.
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer - spinning problem
go to sears.com parts put in model no. and it will show you views of the parts and you can also order new dampner shocks from there
Nov 08, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore washer drains but won't spin.
Sounds like the motor coupling has broken, fairly inexpensive part but does require some finesse to install. let me know if you decide to attempt it.
Oct 15, 2007 | Kenmore 15864/15862 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
