Last time I started up this PC was about 12 months ago. I tried to boot it up this morning and it just beeps. Long intermittent beeps.
  • 13,433 Answers
Can you tell me exactly what kind of beeps are they, long continuos beeps? does the patterns change? if it repeats over and over again with the same long beep. The issue could be your memory, you might have to replace the memory. http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml please go over the beeps code list I posted you and find your beep pattern from the list. In any case, this is a hardware problem, a part from your pc may have to be replaced, you may have to take the machine to a professional to get the machine fixed. at times the fault can be something else than what the beep code meaning implies, I wouldn't buy replacement parts without being completely sure what the issue is.
Posted on Feb 06, 2010
I have a 2006 Kia Sedona. Starting a few months ago, I would turn the key to start and nothing happened. No clicks, nothing. The dash lights would come on like normal while the key was turned. After...
check the clutch start switch or the park neutral switch operations
you need the clutch in to start and there wia switch there that may need adjustment
same for the auto park /neutral switches
check wires
Apr 25, 2017 | Kia Sportage Cars & Trucks
Modle not listed Honda Vision nfme 50 I have had My honda Vision 1986 model for around 18 month. It flew its last mot around 12 month ago. However About 4 month ago returning from work on my scooter...
Its either not getting fuel, poss blocked mainjet, or float needle valve, do you have a constant flow of fuel from the tank, is the bike smoking exsessivly, sounding quieter than it used to do? Maybe the exhaust has become blocked, this was a common factor on this bike, remove exhaust look up exhaust port towards piston, with the piston at the top clean the port with a sharp object scrapeing away all the unburned carbon, start bike up without exhaust and check how it runs,
Aug 29, 2011 | Honda Fusion Motorcycles
It beeps and will not boot an intermittent beep.I checked to see if the components seemed seated correctly as far as I know they are I am a total novice.Any way it will not boot in anyway and the beep was...
Take out the memory thats inside of the computer and reseat each memory one stick at a time in each slot one at a time. Try turning on the computer as well after each reseat to see if the beeps go away.
If that doesn't work then take out the processor and reseat it as well.
If the computer has a video card in one of the slots, take that out and reseat that as well.
If after all of this the computer still beeps, then the motherboard is bad.
Nov 30, 2009 | E-Machines T3265 PC Desktop
No spark very intermittently
Ignition module. They tend to die an intermittent death.
Aug 08, 2009 | 1996 Ford Crown Victoria
C1641 intermittent beeps and won't start up
Is is possible that the RAM you put in was not sited properly. Just check it to see if it is right. You might need to troubleshoot by removing one peripheral at a time. Try removing the keyboard, and turn it on and see what happen. If same, mouse, network card, etc until you find the issue.
Jul 23, 2009 | E-Machines C1641 PC Desktop
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & th
By warble, do you mean a high pitch non stop noise? If so... I think I went through that bout 2 months ago, it was a easy fix. Ifr it is the same problem
May 29, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Intermittantly the car won't start
Main Fuel injector relay is probably the culprit. Buy a second hand one for about 50 bucks and replace it yourself within 30 minutes.
Mar 07, 2009 | 1991 Honda Accord
Wont start after setting
Remove air cleaner Spray carb with carburetor cleaner inside and out let dry try to start..
Probable cause dirty carb or air cleaner choke not set properly or needs adjustment
and cleaned>>Charg battery ans check fluid level fill only with distilled water
Jan 30, 2009 | 1997 Chevrolet Suburban
Boot up ishue
From the sound of it, the PSU is going. The long cool down time would indicate to me that is a rather large component that is not exposed to very much airflow. To help isolate this, you might want to try running the system with the cover off. If the problem stays about the same, I'd say it's the PSU. Check all the fans while you're at it.
Jan 23, 2009 | ASUS P4SP-MX Motherboard
Dead Acer L320
I have the same system acer aspire l320 and had the same problem. They sent an engineer hhhhhh replaced my motherboard This is the only fix to this problm, dontbuyreplacement monitor as u r wasting your money.
Mar 06, 2008 | Computers & Internet
16 people viewed this question
k24674
jasbo
jasbo
