Screen has a fish eye look and colors don't match up, it resets itself sometimes but not all the time.
  • 69 Answers
Sound like loose connections on the convergence ics
Posted on Feb 07, 2010
My gold fish is very timid
The other fish are dominating him. bowl to itself should help
or find out which is the bully and remove
Oct 28, 2012 | Fish
I have a Nikon D-40 I'm currently using a 55-200
Fisheye is the extreme of a wide angle lens. I think you are not using a fish eye lens, but a fish eye adopter. That is a lens that will "shorten" the focal length of a lens most of the time with 30 % sometimes with 50% when you put it in front of your lens. So you could make a 24 mm lens look or act like a 12 mm.
On your tele lens this only will slightly shorten the 55 mm, but even 50 % of 55 is 27 mm and can't be seen as a fish eye.
I think when you put this on a short lens, the picture you get will be round, like you were using a real fish eye.
Feb 28, 2012 | Nikon Cameras
I purchase a 1997 Salem camper trailer and just replaced the Duo therm 13,000 Unit BTU. Everything was good until it was time to connect the wires from the thermostat unit to the analog thermostat on the...
Pay attention to wires from control box itself at the ceiling assy. Sometimes they will use a different color from control box, to thermostat. For example: Green coming out of control box, is attached to a blue running to thermostat, so you would attach that blue, to "G" (fan) on thermostat. Match thermostat colors to what is at the control box originally, not what color they used to run it to thermostat from there. Most try to match them, but others don't. What model Ac unit, and what model of thermostat do you have?
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
Picture shrinks then fish eyes then after a bit it goes to normal size then sometimes sqeezes down to half screen
Sounds like you have it on a sort of "anamorphic" screen zoom. My dtv converter box has a setting where you can adjust the aspect ratios, etc. It may be the same idea for you. I would check under the "zoom" menu or screen preferences. Good luck!
Apr 02, 2010 | Hitachi 60DX10B 60" Rear Projection...
Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
My Lenovo y510 display is blurry. Sometimes it
Need a replacement soon.
If you want a temporary solution for your eyes, use a regular monitor, and plug it to the laptop
Don't forget to rate if this answer helps
Jul 20, 2009 | Lenovo IdeaPad Y510 Notebook
Gear Lube leaking from Prop
Keep an eye on it and put a bucket with paper inside under the motor. You want to know whether the oil is burnt oil from the exhaust or gear lube. You should be able to tell from the color of the oil. Its kind of like soot in a chimney, the exhaust goes through the prop with the oil you added to the gas.
Jun 27, 2009 | Light Outboard Motor Boat Bass Fishing...
Large fish eyed picture
TRY NEW CONNECTIONS AND JACKS ,,ALSO IN THE MENU GO TO COLOR CONVERSION AND USE IT
Apr 19, 2009 | Panasonic PT-52LCX65 44" HDTV
I'm looking for that toaster screen saver. Know where i can get it?
Try this Aquarium Screen Saver
http://rapidshare.com/files/137479681/SF_3D_DASS_1.1DX.rarpassword: borneo
3d Desktop Aquarium Screensaver 1.1dx
« on: August 15, 2008, 03:39:57 pm » Reply with quote Modify message Remove message Split Topic
Watch as your monitor fills with water and real 3D fish begin to swim around the screen you were just working on!
Features:
-Real time 3D fish that don't just swim back and forth, but towards you and away from you, up and down. Like real fish!
-Uses realistic 3D fish models, not just flat 2D images like other screen savers do!
-Dymanic underwater lighting. So if the surface of the water ripples, so does the refracted light!
-Download additional fish with ease! The registered version lets you download fish right into the screen saver from the --Settings screen on the Mac OS X version, and from the website for Windows. It couldn't be easier!
-You can select the background you want! From your wallpaper or a random image (jpg, png or gif files), as well as the option to capture the current screen.
-Select between warm and cold, salt water fish, and fresh water fish, or mix them all together! Remember virtual fish can all survive in the same virtual water!
-The fish's eyes move, so they now look around as they swim across your screen.
-Background Hum/Bubbling sound for that real aquarium atmosphere.
-Many options so you can customize it to your liking. With the full version, you can have as many as 40 fish swimming around at once, as long as your CPU can handle it!
Sep 27, 2008 | Computers & Internet
Patchy color problem
check for bad vga cable , sometime the ground connection breaks loose from inside the cable which can cause of color problems ghusting effects.
try replacing the cable first
Oct 21, 2007 | Dell E153FP 15" LCD Monitor
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
