Question about Mitsubishi WS-55513 55" Rear Projection HDTV
I have a Mitsubishi WS 55513 RPT. I turned it on last night and it is in from the center out.Went to the convergence grid and saw how bad it was bowed. Got into the service menu and reset the alignment and conver back to factory.But w/ no effect. Is there anywhere else I should look?
  • 1 more comment
  • texden Feb 06, 2010
    Where can I purchase these ICs . I have heard of a company here in Allen,Tx that sells a repair kit.I think it's called TVRepairKit.com. Have you ever used one of there kits for convergence IC ?
    The kit comes w/ the OEM Ic's,Resistors,heat sink paste,and detail picture/script instructions. I did repair the capcitors on the DM board a year ago,so i have the desoldering iron and some experience in soldering on circuit boards.
  • texden Feb 09, 2010
    This is wierd, came home after the superbowl and turned the Tv on and everything is straight! Checked the convergence grid and the vert. and horiz. bars aren't cuved.But there is a slight curve on the top left hand corner ( horizontal). The alignment was off a little, so I fine tuned it and the picture looks good.There is a small vert green line on the left side, but its barely noticible. Whats going on here ? Should I go ahead and get the Conv, IC kit or should I check the solder connection on the Convergence Ic's? Have you heard of this problem correcting it's self? The same thing happened with the blinking green light problem. I just unplugged the set for two days and it went through it's boot up and came on,wierd.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
  • Rylee Smith
    Rylee Smith Feb 06, 2010
    If you want to do the repair yourself then you can buy the kit and use it. However before buying the kit just check with them what all they include in the kit, as apart from the convergence ICs you'll also require soldering iron, solder and a voltmeter. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Great then you can purchase the kit, and thanks for accepting the solution.
    Rylee
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Jagged edges going off and on
Go if model here is correct to menu and engage Convergence and advanced to pull up a grid of lines---are they 3d in some areas when this happens?
Apr 06, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Where do u find the fuse in the mitsubishi ws-55513 55in. by the power cord???
Follow the power cord into the back of this TV. You should find a small glass fuse near by. If the fuse is still good, chances are real good that this TV can still be saved. The biggest problem with this TV is the convergence board, which has many, many, many bad grounds that need resoldered. No parts are needed as yet, just some good old fashion rework on the convergence board! Thanks for asking and show a few hands of support!
Feb 21, 2011 | Mitsubishi WS-55513 55" Rear Projection...
Projection TV Convergence problem
go to the Mitsubishi service center to solve your problem
Jun 20, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Image distortion
In the customer menu select convergence and then with the Mitsubishi remote select advanced, you should see a grid of lines.
If red or blue or green are out of position you have a problem in the convergence circuit.
If so, I have step by step instructions for this kind of repair and it can be a do it yourself job.
SD TECH
May 04, 2010 | Mitsubishi WS-55513 55" Rear Projection...
There is green and red line that run across the tv on my mitsubishi hdtv ws5513 anyone know what wrong
WS-55513?
Go into the customer menu with the Mitsubishi remote and select convergence--then select advanced convergence--it will bring up a grid of lines. The best place to do this is on a blank video input.
If the lines are skewed and red or blue out of position and will not adjust--you have a convergence circuit problem.
I have STEP BY STEP, START TO FINISH INSTRUCTIONS FOR THIS REPAIR IN THIS SET.
They will tell you everything you need and how to do the repair. It involves getting at the parts and replacing them.
Most shops are going to get at least 300 for this repair and the parts cost on Ebay for the parts is under 30 dollars.
Let me know if you want the instructions and if this information helped you rate this solution as I do this here for free.
SD TECH
Dec 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Hey anyone there? I have a WS-55513 with a
There are 4 capacitors on the dm board that cause this problem if they are not puffed up, however the dm board will need to be replaced.
Dec 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Blue Convergence
go to main menu , selet advance setting , after that there is another menu where u going to find a convergence ajustment , select convergence adjustment , than choise blue , than after u access to blue color press the audio boton to do the blue , if u can't muve the blue color u going to have a repair service maybe ur stk or convergence ic are bad
Jan 06, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Convergence issues
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
Feb 28, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
