Question about Ovens
Bake element fell apart. Changed it out with replacement element (Emerson CH 5862 PCN 458580, 240Volts, 2800 Watts) Still does not work.
  • 250 Answers
As a general rule, when you change an oven element, you should change the thermostat as well as the element failing can sometimes take out the thermostat as well. (Info. courtesy of a NEFF engineer many years ago as they always change both if an element fails).
If you haven't done so, I would suspect the thermostat.
Posted on Feb 06, 2010
How do i test a control panel of a frigidaire wall oven
Good Morning Friend,
I understand that you want to know how to test the control panel on your Frigidaire wall oven, model# FEB386WECH, due to the bake element not working. I also see that you have changed the bake element and only the broil works. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the bake element is not working. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire 30 in. Electric Gallery Series...
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Changed my Oven element, now top and bottom don't heat up
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Feb 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
Heating element burned up. replaced it and now it does not heat up. it seems to be getting some power because element is warm to touch but does not change color and really heat up.
it sounds like you're not getting 240 volts to the bake element,only 120 so one of the wires going to the element isn't getting power.shut off the power,go in the back and remove the panel where the bake element wires are,check to see if one of the wires fell off,sometimes the connectors get spread apart and when you slide them onto the new element and slide it back into the hole it falls off or a wire could be burnt or when the element popped it took out the clock assy.when you get back there have the element disconnected,make sure the wires aren't gonna touch metal and plug it in and put it on bake,with your meter set on 500 volts touch one probe to the wire and the other to ground,you should read 110 to 120 volts,then do the same to the other wire and you should have the same thing but one of them isn't getting any power and you'll have to trace the wire to see what part is bad.you might have to call in a tech to help you out,also next time send the model number off of the machine so i can look it up.good luck
Apr 25, 2011 | GE Ovens
I need to replace a bake element for a 1950's GE Oven (Model # D14X1DC) but the exact volts and watts for a element are hard to find (236 volts, 3000 watts). Do the volts and watts have to be exactly the...
I found a website that helped, here are some model numbers that work for the GE element. ERB44X126 , Ch44x126-450546 these work for the 3000 watt 236 volts. hope this help.
Nov 07, 2010 | GE Ovens
Whirlpool gold accubake GJP84802
If you can gain access to the clock you could find the wires that goes to the bake element - if you can measure and confirm the resistance of the element chances you may have also fried the relay of the board - check it out
Regards
Sep 06, 2008 | Whirlpool RBS275PD Electric Single Oven
Hooking up new bake element
shouldnt make a difference your elemnt has only 2 terminals 1 wire to each
Mar 19, 2008 | GE JRS06SKSS Electric Single Oven
Ovens Logo
99 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
