Question about Whirlpool GH7145XF Microwave Oven
The tempered glass on the outside of my microwave oven broke. Can I replace this with plexiglass and keep the microwaves from leaking?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
Pliglas does not inhibit microwaves. Generally, even the glass door isn't protection either. A special film, usually a polymer, is applied to the inside of the glass. The 'film' looks like a black or gray 'screen' with little holes in it.
Answer: DON'T DO IT!
Posted on Feb 07, 2010
Glass broke and fell into slits at bottom of oven. Can I still use oven for cooking?
If it is a microwave oven NO YOU CAN NOT! The glass or door needs to be replaced by a technician who has the tools to insure that your oven has no radiation leaks.
Apr 15, 2017 | Microwave Ovens
I broke the range glass door on the fef364dwb. What do I have to do to replace glass in door
If your oven took a hard enough hit to break the tempered glass window, you probably caused other damage inside as well.
If your oven is relatively new, you can probably order a door from the manufacturer or a FixYa.com advertiser.
You may find it will be more economical (and safer) to replace the oven.
May 27, 2011 | Microwave Ovens
My Siemens HF87950GB inner glass panel broke during cooking, do I need to replace the whole microwave oven or just the glass or the door? where I should I go to get a replacement? Thank you!
This is a problem that at least a few others have experienced with your microwave and may be the subject of a recall although I could find nothing on their website.
I would definitely go to Siemens first as this definitely sounds like a manufacturers defect. Even if they have not publicly stated this in a recall, they likely know it is happening and may fix it (even out of warranty) if you push. ConsumerReports.org may be interested... I would talk to them if you don't get any satisfaction from Siemens.
Otherwise, the glass should be standard tempered glass that a local glass shop can get if you bring the door to them, or just a sample of the broken glass (for thickness) along with the internal dimensions of the glass.
Make sure that the metal mesh/screen remains in place and is not damaged, as this is what prevents the microwaves from escaping the cooking chamber.
Siemens Customer Support Website
Siemens Service # 1-866-447-4363
Oct 21, 2010 | Siemens HF87950GB Convection Microwave...
Broken door on my Emerson microwave (MW8985W)
You can order the outer panel. Its available at searspartsdirect.com for about $41. Just type in your model number and look under the "Door Assy" heading. To replace, just follow these steps:
You have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and any screws that may be holding the outer panel in place. Some panels are simply snapped in place.
Remove the broken panel and install the new one. Re-install the door handle and re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you
Aug 27, 2009 | Emerson MW8985W Microwave Oven
The handle broke on my microwave. How do I remove
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Aug 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Replacement parts can be found at any of the following sites:
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
Wheel brackfhet that spins the tempered glass in the microwave.
take a measurement and or bring the glass plate and what is left of the old wheel assembly and try home depot/lowes, or try a used appliance store that always helps me. Robert Alan
Jun 01, 2009 | Kenmore 64002 Microwave Oven
Glass door
It doesn't appear to have been involved in a recall, but since its a non-US model, I probably can't get much more info on it.
Many if not most glass suppliers from the phone book will handle tempered glass too.
Apr 27, 2008 | Microwave Ovens
Whirlpool GH7145XF Microwave Oven Logo
357 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
