Question about Dryers
Our push to start button works, but the dryer does not continue to run after releasing the button. The motor operates and the drum turns, but clothes do not begin to get dry even if we hold the button for prolonged periods. Bad board?
  • 10,319 Answers
If you have to hold the button in to keep running the relay is bad to complete the circuit to the circuit
Posted on Feb 06, 2010
  • 11,896 Answers
Either the door switch is bad or the start button is bad. Most likely your door switch is bad.
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
A buzz sound when pushing start
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 17, 2012 | Maytag Dryers
Drum not turning
Jun 06, 2012 | Kenmore Dryers
My dryer will only run if i hold in the door switch button and turn the drum while i hit the start button.
Jun 04, 2012 | Maytag Dryers
Admiral dryer wont come on
Jun 01, 2012 | Admiral Dryers
Kenmore dryers heavy duties80 series
May 29, 2012 | Kenmore Dryers
Kitchen Aid dryer hums when start button pushed. I can get it to run if I physically spin the tumbler and if there is a very light load inside.
Dec 19, 2011 | KitchenAid Dryers
Dryer won't stay going after button is released and the door safety button is still functioning, also the heating element is still working.
This is what is probably going on. There are two parts in the motor that cause the drum to rotate.
One of them is "start" winding. It literally starts the drum's rotation. Once the drum motor has started the drum to move. The second portion of the motor, known as the "run" winding takes over and keeps the drum turning. When the Drum winding burns out. The same symptom is caused when the switch attached to the motor is also damaged. In your case, although this is rare. I think it may be the switch.
The reason being is that the motor has a combination switch that also connects one side to the heating element. In a nutshell, If you get the dryer not continuing to turn AND the heating element stays on. There is a problem with the switch.
If you get the heating element going on when you push the start button but turns off when you release the button. The problem is the motor having a burned out run winding. Either way, it is less labor intensive to replace the motor when you take it out. Doing it switch is not easy. Hope this helps. If not write back to me and we can continue.
Best, Mark
Dec 28, 2010 | GE Dryers
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
Dryers Logo
67 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
