Question about Drills
Can i do the repair of my 11245EVS by myself( overhaul)
  • lindsay836
    lindsay836 May 11, 2010
    11245EVS what brand ?
    President:
  • 2,030 Answers
I would have to say yes you can if you have the mechanical ability to do it...and you can get the parts
Posted on Feb 06, 2010
What is wrong when the 11245evs drill starts smoking?
It could be that the motor isn't getting the proper current to run, causing it to overheat. Don't use long or low guage extension cords with this type of tool. If the brush holder is warped or the brushes are worn down so that they aren't making good contact with the armature the same condition could arrise. It's possible you have a short or broken wire in the armature or field that's causing it to arc and heat up. Another possibility is something wrong in the workings of the drill that is causing the motor to overwork and get hot. There are a LOT of parts in there so you'd have to take it apart and know what to look for as far as damaged or broken parts.
Jun 28, 2012 | Bosch 11245EVS 2Inch SDSMax Rotary Hammer
How to repair engine overhaul?
An engine overhaul IS a repair...why do you want to repair a repair?
May 17, 2012 | Cars & Trucks
Rotary hammer 11245EVS - Rotates but does not hammer. Thank you. Glen
The motor in these rotary hammers drives two systems in the gun, one to rotate the bit and another that produces the hammering action. The hammer system is mainly a piston driven by a plastic connecting rod on an eccentric cog. The 'usual' failure is the plastic connecting rod but could be any of the gear pins or teeth. It is also possible the striker is stuck in the hammer pipe if the gun wasn't lubricated properly. There are over two hundred parts inside one of these tools so if you're not familiar with repairing one I highly suggest finding a repair shop that works on them. They are good tools and usually worth repairing unless a lot of major parts broke inside.
Aug 15, 2011 | Bosch 11245EVS 2Inch SDSMax Rotary Hammer
Looking for overhall repair manual for type 30 mo#253 ingersoll rand compressor
To my knowledge IR does not make and overhaul repair manual for the 253. They just have a parts manual showing the parts and part numbers. They do make kits, like a valve kit,overhaul kit,rod kit etc. these kits usually have the part brake down in them.
Jul 21, 2011 | Ingersoll Rand Air Tools & Compressors
The pedal mechanism is loose when try to ride
Can you be more specific? There can be several reasons for this. Pedal arms can be worn out, hub in fan can need overhauling. Does the chain move with the pedals? Are the pedal arms loose or the pedals themselves? Pedal hub could also need overhauling. If the overhauling seems to be the issue, best bet would be to take the machine to a local Bike shop, If you're pretty handy, and can do the repair yourself, give me more specific details and I can suggest better instructions on repair.
Mike
Dec 27, 2010 | Schwinn Original Airdyne
My Ebel Sport Classique needs repair for the 181-1 movement Detent. What is the cost of repair and an overhaul for this 8 yr old watch?
Depending what all is involved with the overhaul and other repairs the low end for repair would cost around $375 and may cost as much as $600. Anytime I send a watch in for this kind of repair I expect a free estimate and you should too. If there is a cost for an estimate or if the estimate is around the $600 mark I realy feel you should get a 2nd detailed estimate from a different jewelry store/ repair center.
Oct 21, 2009 | Ebel 1087902 wristwatch
Hollow bolt torque and oil presser warning light
torque it to 65% of the maximum torque rating for that diameter bolt
Jun 25, 2009 | 1998 Subaru Legacy
I have no reverse ;what can i do to fix it myself.
the reverse clutch pack is worn out, there is nothing to do but overhaul the trans, this is not a job for a home mechanic, really complicated and requires allot of training.
Mar 18, 2009 | 1993 Subaru Legacy
Replacement screen for my garmin rhino 120
Hello joewilly31,
It looks like Garmin offers complete factory overhaul for out of warranty Rhino120 units for $99. For complete details on how to get an RMA number and ship the unit to Garmin for repair go to their website at:
http://www8.garmin.com/support/outofwarranty.html
While it may also be possible to purchase parts from Garmin directly, I would recommend against attempting to repair the unit yourself unless you a lot of experience working with and repairing surface mount electronics devices.
Hope this helps.
Ken
"Go Ahead. Use Us."
Jun 10, 2008 | Garmin Rino 120 2-Way Radio
Drills Logo
42 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
