Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
My LACIE external hard drive is not being recognized by my desktop. The green indicator light that changes to orange is not doing so and I'm not hearing the motor. Could this be repaired and if so, how do I go about doing so?
    President:
  • 1,871 Answers
Hello:
If the drive came with an installation disk I would recommend you install the disk first prior to connecting your hard drive to your desktop. It's normally plug and play, this means your drive should be recognized the moment you connect it. However, it's important to insert the disk first and carry out the installation. What version of windows are you using? You can also check out the minimum system requirements that shows on the box.
If the software in the disk is installed and you still have the problem , then go to control panel and click [Add Device] icon and just follow the steps .
If that didn't solve the problem , then on desktop go to my computer and click right mouse and go to properties , there click on system . on system click on [device management] , there you'll find all hardware devices that are already installed on your system . just check if your external hard drive existed or not . if not , then try again the above steps after you uninstall the software of your hard drive .
good luck .
Posted on Feb 06, 2010
Rocstor icon disappears from desktop and light is half orange/green
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
My lacie hard drive is not spinning up. the light
if still in warrenty return to reseller for replacement but if outta warrenty open it up and try the hard drive in a pc and see if it works ok if it does u just need a replacement external caddy which can be found quite cheaply on most auction websites ;)
Mar 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
What are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Sep 19, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
Lacie hard drive
The problem is just external...Hdd is fine..Just buy new external couse there is no way to repair it
Jan 12, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Flashing led light on my hard drive
well the best thing i figured out to do was to purchase a new case. i think the case burned up. i pulled the hard drive out and hooked it up to another drive so to see if it would work. the drive works just fine in the other device, so i ordered another case.
Nov 06, 2007 | LaCie 301103U 500 GB USB 2.0 Hard Drive
Can't Connect
Hi Jesse. Have you tried, or can you try the drive on another computer ? That's a good way to check if the drive itself is getting defective. I'd try that one first ! It could be also the firewire cable, have you tried another one ? Else, it could be the hard drive in the lacie inclosure that's getting weak (you might wanna backup your data if you ever get it to be recognized, if there's anything that's important on it), or the lacie enclosure's firewire controller that's doing freegames. I've seen such problems more than often, and if nothing has changed in your setup since it was working, i'm betting on the failed drive. They aren't that reliable as we know. Hope that helps a bit. Thanks! cheebster.
Jun 18, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
268 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
