Question about Maytag Performa PAV2200
My performa washer is making loud noise from where two hoses conect on inside bottom left maybe pump how do i get a new part or what is this part called
  • 56 Answers
That is the drain pump, belt driven with 3 3/8in screws holding it to the floor of the unit
Posted on Feb 06, 2010
Loud and noisy when the wash cycle starts.
Slide the unit out from the wall and open the small access panel on the back, bottom left side. 98% of the noise problems from this model is do to the bad design on the drain pump which has since been redesigned and will need to be replaced. Here is the new pump.
This washer pump has been redesigned by the manufacture. The mounting plate is no longer required. It now mounts directly to the base of the washer.
Nov 03, 2012 | Maytag Performa PAV2200
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
Our maytag performa top load washer PAV2200 stopped in the middle of wash cycle and we heard a loud pop and then smelled burning rubber. My husband has pulled the belt off the bottom and its still in one...
Check the drain hose from the drum to the pump assembly. Alternativly look for the large capacitor that should be mounted to the internal framwork of the machine, see if has popped. They can make quite a bang when they go,
Jun 20, 2010 | Maytag Performa PAV2200
Maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Sep 29, 2009 | Maytag Performa PAV3200
My washer runs fine until the spin cycle then it started making a loud noise, and not spinning, i emptied it and let it sit, now it spins but not nearly fast as usual. and the noise is gone after letting...
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Sep 12, 2009 | Maytag Performa PAV2200
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Washing Machines Logo
163 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
