Question about Tascam 2488 Portastudio Multitrack Recorder System
I'm setting up a side rack of equipment i would like to incorporate into the tascam. I want to use an effects unit,bbe sonic maximizer a tc helicon harmonizer and possibly an parametric eq. I'm not sure in what order to put them in and where to come out of tascam to utilize them. is there a way to chain them together and still utilize them seperatly or not at all if I choose?
    Brigadier General:
  • 8,546 Answers
Get a dbx 400x Program Route Selector or something like it. (eBay). It will allow separate independent attachment and selection via front-panel switches of three processors and three tape decks to a single Tape Monitor loop; and the processors can be placed either before or after the processors or source, again via switches. If you have more processors you can always line some of them up in-line on a single processor loop. I do it on mine.
Posted on Feb 06, 2010
How can I connect A BBE482i Sonic max. to this mixer amp and how to hook it up, will it help my sound system I have two Pr15 mains and two PV12 monitors
Go from the main out on the front panel to the left bbe input then from the left bbe output to the power amp 1 input. Then do the same from the monitor out to the right side and back to power amp 2. BBE units can enhance your sound, but too much will tend to sound brittle.
Mar 04, 2016 | Sonic Music
When I burn my mastered tracks to CD, the volume is so quiet it can hardly be heard at all. The sliders are up almost full.
I believe you need to install an BBE Sonic Maximizer to boost your signal recording before your DP-02
Jul 13, 2011 | Tascam Dp-02cf Digital 8-track Recorder
I want to buy a voicelive touch from the states,what do i need to do to make it work on australian 240 volt power
Check your pwer adapter as MANY of them will take 100 to 240 volts inout... if yours does, you are go to go... else here is one that will work as it is a worldwide type:
http://lcdpayless.com/productpage.php?productId=6679
Mar 12, 2011 | TC Electronic TC Helicon VoiceLive Touch...
My G Major 2 has a signal from unit to mixer and from the mixer into another board. All is well as far as the chain is concerned. The guitar tuner works fine but for some reason I cannot hear any effects....
Have you remembered to use BALANCED TRS cables in and out of this unit?
Your description does not give us enough info about how you have this chained together.
DO REMEMBER that ALL interconnected equipment MUST be powered from the sme source or receptacle for system safety. It sounds like you have mixers tied into mixers. Check the power distribution. Many destroy equipment because stage power is used one place and mixer power is taken at the back of a room for example. The pro's know better than to do this and a power distributor using extensions to feed the remote devices are used.
SOME of the effects involve stereo to create, and the output of this device MUST maintain stereo all the way to the stereo main speakers. If your mixer goes to another board, it MUST do so as stereo and if they run it to two channels, those MUST be "panned" to opposite sides. That ALSO goes for your mixer itself... if you use two channels, they must be panned.
Feb 12, 2011 | TC Electronic G Major 2 Rack Effects...
Setting up a Behringer PMP5000
You can do the effect via the "POWER AMP INSERT" jacks.
Use TRS interconnects to yout effects unit.
If the effects unit does not have TRS type bi-directional in/out ports, you MAY need to make special cables to connect the units. Refer to figure 4.5 on page 9 of your PMP5000 user manual for INSERT connections.
Jul 15, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Sonic maximizer
To use the maximizer as a send effect, connect the effect send (1 or 2) to the input on your maximizer, then connect the output from your maximizer back into any input A thru G on your 2488. You then assign the track you want to maximize to the correct send (1 or 2) using the send key and then assign the input to a track to record to.
To use a maximizer as an input effect (assuming guitar) simply plug yoiur guitar into the maximizer and then patch the maximizer to input H (Hi Z input of the front panel of the 2488). Assign input H to a track to record and this will record the maximized input signal.
Jan 03, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
118 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
