Question about Tascam DR-1 MP3 Player
File error tascam dr-100
One of 3 wav file I recorded on my tascam dr-100 will not play back. THE FILE IS 1.5 GB in size so I know there is something recorded.
5 Suggested Answers
SOURCE: Tascam dr-1 recording problem
There is a "PB Control" button. I had the same problem. You've inadvertently told it to change the speed or something on playback. Make sure that none of the indicators at the top of the screen are active (i.e., white letters on black background). Press the PB Control button to toggle it on/off. Also, any files transferred to a computer will not be affected.
Posted on Feb 08, 2009
shadow83
  • 496 Answers
SOURCE: I cant' read a WAV file with the Zen V plus I
try and convert your wav files to mp3 or wma whatever you prefer just google wav to mp3 converter that will ensure that your player will read it
Posted on Oct 07, 2009
lexzy80
  • 943 Answers
SOURCE: Does anyone know HOW to get the case open on a
It is not advised you do this by yourself as you would be making your warranty void and you could cause more damage to your device.
It is best advised you send it to a repairer.
Posted on Feb 13, 2011
SOURCE: DR-1 MAC FINDER does not see it!
I had a similar problem. What i did was to replace the tascam provided cable with another one (similar) from Iriver t30. works wonders. found out that the original cable couldnt plugged in properly to tascam although it did recharge the unit.
Hope that helps.
Posted on Feb 28, 2011
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
Rc-50 recording silent wav files
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Mar 22, 2014 | Boss Rc 50
Voice recorder won't play back sound
Can you put this problem to an expert
Dec 15, 2013 | Tascam Dr-05 Portable Recorder
My tascam dr 100 gives a 'writing failed' file error' message and stops recording
Try using a smaller memory card. This only happens to me when using a 4- or 8-gig card. 2-gig and below, No error.
Feb 24, 2012 | Tascam DR-1 MP3 Player
Corrupted Audio File on Tascam using Scandisk III 8Gb
You should be able to view the file on a computer. Select the file and delete it. Presumably there was an error after the file was recorded and all you probably have is the file name and a shell of a file. Hence it being only 30K.
There is nothing you can do with the file. And whatever you recorded was lost.
A 40 minute wave file would be massive. Try recording as MP3 for long files. You might be OK at 3 to 6 minutes with a WAV file.
Mar 01, 2018 | Tascam 2488 Portastudio Multitrack...
Having trouble transfering my wav files from computer to tascam ( dp 02) even from cd to tascam . so i am unable to use .help? i have transfered my mp3 audio files to wav and tried to drag and drop from...
I had the same problem too but I figured it out. First you have to make sure your wav file is converted to (MONO) as opposed to Stereo, (which is the default channel setting). The best thing to do is to download a converter program, in my case I downloaded AVS Converter program which all I did was upload the wav file switch it to Mono 1.0 and that was that!! The Cons: for this program it costs money to download for your own keeping. I also suggest Audacity program my computer wont let me download it but a co-worker of mine has it and he said it's free to download.
Feb 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
Load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
Corrupted WAV file will not play or transfer to computer
yes!...
after try, try and try again... i have the solution now!
my english is very bad but i will try write good...
ok... i use one file recover (have many softs this type in internet...) i used this: R-Studio
try this and all will be ok!
good luck for yours!
Abimael - Lgm legrandmenteur@hotmail.com
Dec 22, 2008 | Zoom H4 Handy Recorder
Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Nov 09, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DR-1 MP3 Player Logo
633 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
