Question about Toshiba Satellite P105-S6084 Notebook
Has power, but will not post up or go thru boot
Has power, but will not post up or go thru boot sequence
  • 316 Answers
Hello my friend,if you sure that is having power and is not motherboard or CPU error then you should try resetting your bios settings or check if the bios battery is dead.You should take it to a repair shop to take a look or tell me if you want to try to change the cmos battery but remember that the warranty will be void and you may harm your computer.
Posted on Feb 06, 2010
How to reboot from boot sequence
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. You want to boot from the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Dell XPS M1730 Laptop
When i boot up the computer it starts beeping immediately, otherwise boots just fine
The beeps are part of the boot sequence, more normally called the post report. The beeps length and number usually indicate a problem.
Check with the abit website, you need the post sequence for your motherboard.
Usually, with a post report, you get a single beep which means everything is tickety boo.
Feb 06, 2011 | Abit AV8 Motherboard
I have a systemax desktop that runs XP. I installed a Seagate 2T external hard drive to store pics, files, etc. When I turn on the systemax, it attempts to boot from the external hard drive and will not...
Pressing f10 during system restart will gain you access to the bios. Using the arrow keys scroll to the boot sequence and hit enter. this should allow you to choose from , and select a primary boot order sequence. Follow the on screen instructions to make the changes. Then hit esc button. be sure to save and exit setup.
Jan 23, 2011 | Systemax (036052) PC Desktop
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
LAPTOP, HP, PRESS POWER BUTTON, IT STARTS IT BOOT SEQUENCE, THEN 26 TO 27 SECONDS INTO IT, IT SHUTS DOWN MOMENTAIRLY AND RESTARTS IT BOOT SEQUENCE... NO MONITOR VIDEO, HEARING NO POST BEEPS, AND WILL...
it could be any of the two. problem with your power supply section and mainboard. the reason it shut down repeatedly, is the unstable supply of dc voltage on your laptop. try using another charger/adaptor.if the mainboard is the culprit. you have a serious problem. visit your local service center.
Jul 13, 2009 | Intel 430180-001 - HP Pavilion dv8200...
Dell Dimension 4700 won't boot properly.
Disconnect the hard drive and the floppy drive cable at the mother board. The retry POST and try to clear up any problems in POST. If this works fine then the floppy drive cable is either reversed at the unit or the hard drive is jumpered wrong.
Apr 04, 2009 | Dell Dimension 4700 PC Desktop
Boot sequence manual
When you hit the power button on your computer a whole lot of stuff happens. We call this the boot process. In the days when I first started using computers there was literally a "boot disk", a floppy (5.25" not a 3.5") disk that told the system where to go and what to do so that the operating system would start up. Since then the boot sequence has become somewhat more complicated. So let me take you thru the steps the computer takes to get started. For my example I'm going to use a Windows XP system.
  1. First is the POST, this stands for Power On Self Test, for the computer. This process tests memory as well as a number of other subsystems. You can usually monitor this as it runs each test. After that is complete the system will run POST for any device that has a BIOS (Basic Input-Output System). An AGP has its own BIOS, as do some network cards and various other devices.
  2. Once the POST is complete and the BIOS is sure that everything is working properly, the BIOS will then attempt to read the MBR (Master Boot Record). This is the first sector of the first hard drive (called the Master or HD0). When the MBR takes over it means that Windows is now in control.
  3. The MBR looks at the BOOT SECTOR (the first sector of the active partition). That is where NTLDR is located, NTLDR is the BOOT LOADER for Windows XP. NTLDR will allow memory addressing, initiate the file system, read the boot.ini and load the boot menu. NTLDR has to be in the root of the active partition as do NTDETECT.COM, BOOT.INI, BOOTSECT.DOS (for multi-OS booting) and NTBOOTDD.SYS (if you have SCSI adapters)
  4. Once XP is selected from the Boot Menu, NTLDR will run NTDETECT.COM, BOOT.INI and BOOTSECT.DOS to get the proper OS selected and loaded. The system starts in 16-bit real mode and then moves into 32-bit protected mode.
  5. NTLDR will then load NTOSKRNL.EXE and HAL.DLL. Effectively, these two files are windows XP. They must be located in %SystemRoot%System32.
  6. NTLDR reads the registry, chooses a hardware profile and authorizes device drivers, in that exact order.
  7. At this point NTOSKRNL.EXE takes over. It starts WINLOGON.EXE that in turn starts LSASS.EXE, this is the program that display the Logon screen so that you can logon.
Nov 05, 2008 | Computers & Internet
Toshiba Satellite P105-S6084 Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
