Question about Dell Computers & Internet
When pressing a hyperlink using outlook 2007 mail using vista operating system on my Dell Inspiron 530, an applet appears '' the operation has been cancelled due to restrictions in effect on your computer''. How do I resolve this to enable me to use hyperlinks on email?
  • 5 more comments
  • termarken Feb 06, 2010
    I do not se any blue bar that says down load picture on microsoft 2007 email
    When pressing a blue hyperlink on an email using microsoft email 2007, I get an applet stating "the operation has been cancelled due to restrictions in effect on this computer. Please contact system administrator." How can I resolve this to successfully use hyperlinks on emails I receive?
    Hi did that on explorer 7 and got to reset then got applet stating all windows and programs must be closed before computer can resset. I closed all window and programs but still get this applet. What do i do know?
    Also my computer doesn't have a run on it so I couldn't do last suggestion
    Believe I might have internet explorer 8 but can't find it on computer
  • termarken Feb 07, 2010
    When using email and when I press a blue hyperlink on that email I get an applet that states"the operations have been cancelled due to restrictions in effect on this computer. Please contact your program administrator". I am using windows 8 on a dell inspiron 530 computer. How do i resolve so that hyperlinks can be used?
    What trust center? I go to tools and I don't see a trust center? I can click on advanced settings and go to security and see a trusted sites but i put bar from medium to low and operations applet has been cancelled comes up when pressing hyperlink still.
  • Dell Master
  • 1,183 Answers
The problem can be caused due to configuration issue with internet explorer. Use the link below to solve the problem
http://support.microsoft.com/kb/310049
If you are using windows Vista operating system or windows 7
1. Click on the Pearl (start) button
2. In start search type " DEFAULT" Click on default programs in the popup menu
3. Click on Microsoft Outlook and click on set as default .
Thanks for using Fixya
proton
Posted on Feb 07, 2010
  • 345 Answers
This is issue with permissions in security settings. You can go to tools and then trust center and make sure it is not disallowed to open HTML messages under automatic download.
  • 233 Answers
You may be able to resolve the issue by resetting Web settings in Internet Explorer 6 or Internet Explorer 7. To do this, follow these steps, as appropriate for your situation. Internet Explorer 6 loadTOCNode(3, 'resolution');
  1. Start Internet Explorer 6.
  2. On the Tools menu, click Internet Options.
  3. Click the Programs tab, and then click the Reset Web Settings button.
  4. Under Internet programs, verify that the correct e-mail program is selected.
  5. Click to select the Internet Explorer should check to see whether it is the default browser check box.
  6. Click Apply, and then click OK.
    Note You may receive the following message when Internet Explorer starts: Internet Explorer is not currently your default browser. Would you like to make it your default browser? If you receive the message, click Yes.
Internet Explorer 7 loadTOCNode(3, 'resolution');
  1. Start Internet Explorer 7.
  3. Click the Advanced tab, and then click Reset.
  4. Click the Programs tab, and then click Set programs.
  5. Click Set Default Programs.
  6. Click to select Microsoft Outlook, and then click Set this program as default.
  7. Click OK, and then close the Default Programs dialog box.
  8. In the Internet Options dialog box, click the Programs tab, and then click Make default under Default web browser.
  9. Click OK.
OR
Note : Use this method only if the earlier instructions for each browser do not work to resolve this problem. Export the registry key from another computer loadTOCNode(3, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. Locate the following registry key: HKEY_Local_Machine\Software\Classes\htmlfile\shell\open\command
  4. Click the command folder.
  5. On the File or Registry menu (depending on your operating system), click Export.
  6. Note the location of where the file will be saved. The registry file can be saved directly to the hard drive or floppy disk.
  7. Type a unique file name, and then click Save.
  8. Quit the Registry Editor.
Import the registry key loadTOCNode(3, 'resolution');
  1. Copy the Exported registry key to the desktop on the problem computer.
  2. Double-click the .reg file.
    You receive the following message: Are you sure you want to add the information in drive: location file was copied to\file name.reg to the registry?
  3. Click Yes, and then click OK.
Posted on Feb 06, 2010
  • Deny Mulia
    Deny Mulia Feb 07, 2010
    Did you try 2nd resolution (
    Export the registry key from another computer)?
  • Deny Mulia
    By the way, I never said "trust center" in my step.
    If my 1st solution not working try my 2nd one:
    Use ComboFix to repair your computer registry, combofix is free tool, where you can download Here.
    Just download it, run combofix, follow the instruction, just click OK until start scan.
    after finis reboot your system.
  • Dell Master
  • 4,806 Answers
Try this >>>>
Open Outlook 2007. Select the email which contains the hyperlink. In the right hand pane, above the email itself you will see a blue bar with "Click here to download pictues" etc. Click on that bar and it will go an orange colour. Wher it says download pictures, click on that.
The full email will now load up and you now should be able to click on a hyperlink from within the email.
Please post back if you still have the same symptoms.
Good luck.
Default mail client
It sounds like you are trying to click on a hyperlink to email someone, like at a website. These hyperlinks are programmed to open an email client like Outlook, or Outlook Express and open a new mail message with the email address line populated.
If you are using a WEB based email like Yahoo, Hotmail and the like, then the hyperlink will not work, and you get the error you describe. Generally it isn't worth the time and effort to setup an email client if that is the only reason you are doing it.
SO, generally, I just open my email, then type the email address of the hyperlink (Support@dell.com for example)
Jan 12, 2010 | HP Pavilion dv9000z Notebook
Outlook 2007 Windows Vista will not allow hyperinks
You might find the answer to your question here:
http://office.microsoft.com/en-us/outlook/HA012299621033.aspx
In short:
Stop disabling links and functionality in all messages
1. On the Tools menu, click Options.
2. On the Preferences tab, under E-mail, click Junk E-mail.
3. Clear the Disable links and other functionality in phishing messages (recommended) check box.
Note If you decide to select this check box later, Outlook will disable all the links in messages that were evaluated as suspicious by the Junk E-mail Filter, and you will receive warnings about suspicious links.
Also read the complete topic. There is some interesting stuff inside..
Jun 01, 2009 | Microsoft Office Outlook 2007: Windows
My yahoo mail gets dumped into outlook express. How do I stop this
Go to start>set program access and defaults>and change the setting for your default e-mail program.
Also check the mail profile settings of your mail in control panel...
If you have further questions, let us know if you're in xp or vista, and what email provider you're using.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 17, 2009 | Dell Inspiron 530 Desktop Computer
Is this sending or recieving of emails that the hyperlinks dont work? If you are sending you have to use the CTRL+Click method to test the link. the recipent should be able to just click the link
Mar 17, 2009 | Microsoft Office Outlook 2007: Windows
Clicking outlook express hyperlinks gives not responding message
First download and reinstall Internet Explorer, that has Outlook Express built in. See Internet Explorer: Get It Now.
If that does not work, do system restore to a date before you started having the problem. See System Restore on Windows XP.
Jan 22, 2009 | Microsoft Windows XP Home Edition
Black screen
you restore the pc back when it was working fine,you can do in safe mode
May 30, 2008 | Dell Inspiron 1501 Notebook
Getting a manual
Use this link download varies manual concerning to system
http://searchapj.dell.com/results.aspx?s=dhs&c=in&l=en&cs=indhs1&k=Dell+530+Inspiron+manual&cat=all
the above will give below information on the site
Appendix: Dell Inspiron 530 Owner's Manual ... Appendix Dell Inspiron 530 Owner's Manual Specifications ...Cleaning Your Computer Dell Technical Support Policy (U... Product name: Dell Inspiron 530 Model number: ... Setting Up and Using Your Computer: Dell Inspiron 530 Owner's Manua... ...Using Your Computer Dell Inspiron 530 Owner's Manual Front View of the Computer...your computer when you access the Dell Support website or call technical...specifications indicated in this Owner's Manual reflects the maximum ambient operating... Glossary: Dell Inspiron 530 Owner's Manual ... Glossary Dell Inspiron 530 Owner's Manual Terms in this Glossary...code located on a sticker on your Dell computer. Use the Express Service Code when contacting Dell for assistance. Express Service...
May 25, 2008 | Computers & Internet
Cant open attachments
That's not a problem with Vista, rather it's most likely a problem with the web server. Make sure you entered all your web server information in correctly (pop3, SMPT, etc), and make sure your mail server supports MS Outlook 2007. Just double check everything. If that doesn't work, try completely un-installing and re-installing Outlook 2007. If all fails, try downloading a 3rd party mail application and see if that works.
Feb 09, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
