Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
I need to remove the table from the base. - Makita 10" Dual Bevel Sliding Compound Miter Saw
  • 2,176 Answers
Generally you would have to remove both kerf boards and you will find a hex nut in the recessed area of the table, on a Makita is a 13MM remove it and then while lifting up on the table wiggle it and it should come apart. Let me know if you still need more information.
Posted on Feb 07, 2010
How to attach to my craftsmen router? I've inherited my Dads router, router table,and router guide. I have no idea how to use them. Will you please help me?
I have a craftsman router and table. On mine you remove all the screws from the base plate, set the base plate aside and use same screws to mount the router to the underside of the table.
May 08, 2017 | Saws
Where can I find an assembly manual?
Amazon.com - Windermere Counter Table - Coaster 100438 ...
www.amazon.com > ... > Furniture > Tables
Amazon.com, Inc.Include assembly service ' Price $33.38 ' ZIP Code ... Coaster Hyde Counter HeightSquare Dining Table with Storage Base in Cappuccino(Table only).
Coaster Hyde Counter Height Square Dining Table with ...
Amazon.com, Inc.Amazon.com: Coaster Hyde Counter Height Square Dining Table with Storage Base ... Learn More; ASIN: B00399COLM; Item model number: 100438; Average ... Also, theassembly instructions manual did not come, however, VisonDecor did ...
Nov 01, 2015 | Coaster 100438 Counter Height Dining Table...
Hello I have a ryobi router table ART3 what router will fit this table the manual say's a ryobi 163 but I live in Australia and can't even find a second hand one , their are plenty in America but they are...
If its not and adjustable table and you can't find one, modify the mount to fit yours.Most of the time all you will need to do is drill 4 holes in the top of the base to match your router base. Easiest way to set it up is to remove the router base from your unit and use the holes as a template to drill the holes.
Feb 06, 2015 | Ryobi Tools & Hardware - Others
How do you install a ridgid router to a craftsman router table?
Brenda, They are just saying that if the router is too big, it won't fit. The sub-base is the plastic, usually black, disc on the bottom of the router. This disc is about 6 inches in diameter and about 3/16 inches thick. It is usually held onto the base of the router with three screws. The base is the big aluminum piece about the size of half a loaf of bread that has the handles and into which the router main part (the motor) slides into. For most router tables, you mount a router base (with the sub-base removed) to the underside of the table with screws. The router table becomes a giant upside-down sub-base. If your base fits, and the screw holes line up, you are good to go. However, it is very helpful to have an extra router base (without handles) to leave permanently attached to your router table so that you can easily swap the router between the table and normal use. Good luck!
Jan 13, 2013 | Saws
My pro 2096 has no volume
  • You have to uses external software on this scanner.
  • Custom GRE/Radio Shack Frequency Table
  • Table 1 ---
  • With WIN96 software for the PRO 96/2096 scanner:
  1. Prompt "MULTI TABLES"
  2. Prompt "EXTENDED TRUNKING TABLES"
  3. Do not prompt any "STANDARD PLANS"
  4. "CH LOW" 8192 "CH HI" 12287 "BASE FREQ" 453.0250 "OFFSET" 8192 "STEP" 12.5
  5. "CH LOW 12288 "CH HI" 16383 "BASE FREQ" 450.0000 "OFFSET" 12288 "STEP" 6.25
  6. Clear all other trunking tables, and prompt "OK"
  7. Now save your file.
  • Custom Uniden Frequency Tables
  • Table 1 -
  • Base: 452.0000
  • Space: 12.5
  • Offset: 380
  • Table 2 -
  • Base: 460.0000
  • Space: 12.5
  • Offset: 570
  • If you have not done this then you will receive no audio on digital reception.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 06, 2011 | Radio Shack Pro-2096 Base Scanner
When I turn the table I am getting metal on metal grinding and is tough to turn .... how do i adjust table? dual compound makita ls1016l miter saw
you don't adjust the table, you need to remove the table from the base and clean the surface, when you take it apart you will see what I am talking about. To do this first unplug the tool and remove the fence and kerf boards, under the kerf boards you will find a 13MM hex bolt just like on the fence, remove the bolt and lift the table off the base, clean the wear plates and lube them with a light coat of grease, on the outside rails you will see what is causing your problem, clean with a surface conditioner or fine sandpaper, lube this area also.. Make sure you do all the sides for a smooth turn, reassemble the table to the base in reverse order and install the bolt, I usually tighten all the way snug and then loosen till you can turn the table freely making sure not to loosen too much or the table will rock. Reassemble the fence squaring it to the blade and replace the kerf boards. It sounds complicated but really it is not. This is the only way you can get that metal to metal rough turning repaired. Let me know if you need more assistance
Feb 27, 2011 | Makita 10" Dual Bevel Sliding Compound...
I need a base plate for a Freud FT1702VCEK to make a router table will a FT1700 work.
I don't think I understand, because all routers come with a base plate, and to make a router table, you would want to remove the base plate from the router, and use the holes underneath that.
But there was a whole lot of discussion about the very same subject on a router forum, so maybe you will find the answer you need there?
http://www.routerforums.com/guide-bushings-templates/12216-freud-ft-1702-vcek-combo-router.html
Oct 13, 2010 | Freud FT1702VCEK 2 1/4 Hp Router With 2...
I need to remove and replase the arbor housing from main base, any idea how to take the housing off?
on most table saws a allen wrench is needed to remove the arbor
Aug 21, 2010 | Saws
What's the smart way to remove the motor for
i wouldn,t remove unless you think needs new bearings or cannot get to the brushes, turn upside down if has base cover remove and blow out best you can be sure no water in air line.
Jan 05, 2010 | Bosch Electric Table Saws
I have an Emerson (2 weeks old). It heats well but there is a thumping noise when the table rotates and sometimes the table will operate with a jerking motion.
It sounds like the table is'nt positioned properly on the base it sits on, most are not attached and can be easily removed for cleaning purposes, try repositioning the table on the base.
Mar 10, 2009 | Microwave Ovens
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
