Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
I have to move my 57f500 across town with a trailer. What do you recomend on how to do this.Any special measures to secure the lenses?
So is the trailer park a real place then? An actual trailer park? Can you just move there then and does anyone have the name of the trailer park where it was filmed?
The first 4 seasons were filmed in different trailer parks in Nova Scotia, Canada. The pilot was filmed in Spryfield, Nova Scotia. The first season was filmed in Sackville, the second in Dartmouth, the third in Lakeside, the fourth in Dartmouth again (in a different park than the second). For the Christmas special and season 5 and onward, they have used a park they purchased in Dartmouth.
Sep 04, 2016 | Trailer Park Boys (2001)
We have a rheem 71 40D B and it is leaking, what is a good replacement unit for mobile home
Any specially sized unit for a mobile home should be fine. Just make sure that the amperage and voltage requirements are the same so you do not have a wiring hassle.
Mar 19, 2015 | Rheem Water Heaters
What is the total length of a 1988 32" jayco travel trailer to the hitch
If you have the travel trailer do the obvious and take a tape measure out and measure it. If you don't have the travel trailer contact jayco trailers and talk to the sales manager.
Jan 20, 2015 | Cars & Trucks
Disassemble Toshiba 65H80 tv
No, cabinet is glued and screwed---entire front screen can be removed and the mirror inside also(be very careful with that) as they are the two things that get damaged most when transporting a set.
Moving a long ways or just across town?
Apr 22, 2012 | Toshiba 65H80 65" Rear Projection...
My 2001 GMC Yukon 5.3l 4WD SUV is having (2) transmission problems. 1.) When cold, it shifts HARD from 1st into 2nd but after the 1st time while the engine is warm, it shifts smoothly. It started doing...
Does the trany fluid smell burnt? Might want to have the trany flushed - torque converter too - and replace the filter in the trans. FYI you may know this but it is not recomended that overdrive be enabled when pulling a trailer - especially a heavily loaded one. Does your town have lots of hills - this is an added stain on the trany.
Nov 18, 2010 | 2001 GMC Yukon XL
How can I measure a sunglasses frame?
A frame has 4 basic frame sizes.1. Eye Size - refers to the horizontal width in millimeters of one of the frame's lenses.
2.Bridge Size - measurement is the distance in millimeters between the two lenses. It is measured between the two closest points of the two lenses.
3.Temple Size - is measured along the length of the temple, from one end to the other, including the bend.
4.Vertical Size (B) - refers to the vertical height of an eyeglasses lens, and is measured from the tip to the bottom of the lens aperture of the frame. The measurements are taken from a horizontal line intersecting with the top of the lens, to the horizontal line intersecting with the bottom edge of the lens. The B measurement is only important when ordering multifocal lenses; follow this link to read more about progressive lenses.
Nov 07, 2010 | Clothing Accessories
My o3 navigators adjustable brakes will only move about 1/2 inch either direction. It's fine if they don't work but is there any way to move them to the farthest position manually?
With both tail light lenses removed locate the black with yellow wires and the dark green with brown wires coming out of the brake/tail/turn signal sockets.
The black with yellow wire will be the running lights or tail lights and the brown wire from the trailer harness will attach to it.
The green wire on the trailer harness will be the right turn signal and will be attached to the passenger side tail light harness dark green with brown wire.
The yellow wire on the trailer harness will be the left turn signal and will be attatched to the dark green with brown wire on the drivers side tail light harness.
The white wire on the trailer harness is the ground wire and will need to be attached to a good ground. Is it pretty easy to crimp an eyelet onto the end of the wire and use a self tapping screw to attach it to the body behind one of the tail light lenses.
Here is a trailer light/wiring article I have done in the past. It has a couple of good tips you may find useful.
http://www.hotspotoutdoors.com/forum/ubbthreads.php/topics/1425999/1/Trailer_Wiring_101
Oct 27, 2010 | 2003 Lincoln Navigator
I have a 1977 chrysler 22 sailboat and I am converting a power boat trailer into a sailboat trailer. I'm trying to figure out how far up I need to put the outer supporting boards on the trailer.
I did same reciently for a Nolex 25. Easiest is to measure and copy someone else's trailer.
Would suggest putting boat on the hard , measure the width between mudguards on your trailer ( you want the boards as close to the guards as you can) halve your number , measure same out from centreline of yacht and up to hull from ground. Transpose measurements to trailer.
Hardest part is guessing the correct balance point ( distance from centre of axles to winch) this is so much easier if you have one to copy.
Try to leave everything adjustable in order to tweak once your boat is on the trailer.
Remember the centre rollers need to carry most of the weight, not the boards.
Mar 28, 2010 | Boating
Can I move this TV on a trailer?
You would be best moving it on a truck, vs. a trailer. I know that height is a concern, but this damage due to debris can be minimized by judicious use of refrigerator boxes (see local sears store) to protect it.
Either way, plan on having to realign the screen when you finally get it moved. This is normal. Moving on a trailer just might permanently misalign the screen so that the processor in the tv cannot compensate for it.
UHaul also rents blankets / pads without having to rent anything else as well. You might consider that option.
On the other hand, this tv was likely trucked across America inside a trailer on the back of a semi. But that trailer also had a lot more weight in it as well. Personally, I would move it using a pickup.
Dec 21, 2008 | Toshiba 57H81 57" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
13 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
