Question about Apple 23" Flat-Panel TFT-LCD Cinema HD Display
Two Apple 23" Displays (Switching Parts)
I have two Apple 23" HD Cinema displays. One has a defect common to many of the early iterations of this model (magenta color cast - not fully correctable with calibration). The second is a later model without the problem. However, after a power failure it stopped working. I am thinking it burned up some component (fuse?) in the display. Would it be possible to replace the blown part in the second display with the same part from the first display. Any ideas what part that might be given my meager information. Thanks, Larry
  • Apple Master
  • 10,028 Answers
Look for puffy electrolytic capacitors on all the boards. If the tops are not flat they need to be replaced. Sometimes they will expand and shed the plastic covering or expel its contents through the bottom which can be easily seen. The fuse and power supply boards should swap.
Posted on May 10, 2017
2 Suggested Answers
SOURCE: Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Posted on Oct 31, 2008
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
Can someone help me a circuit diagram for the apple 23" HD monitor
http://tim.id.au/laptops/apple/displays/cinema_hd_display_23.pdf
May 26, 2012 | Apple A1082 CINEMA DISPLAY 23" LCD Monitor
Power connector on cinema display is damaged. Can it be replaced?
Hello, GREAT NEWS!!! Yes you can replace it. Try going onto Ebay and punch in: A1097 Apple cinema display power ac adapter 90W 23" LCD.
May 05, 2010 | Apple Cinema Display 23" HD Monitor
Just bought a use apple 23" hd display. The color seems to be somewhat yellow and is not a vibrant as my other apple 23" why
Optical components vary, especially when they have been pre-owned and subject to unknown temperatures and environmental conditions.
You can tune the yellow cast out of your monitor and improve the color range by opening Apple Menu / System Preferences / Displays, selecting the Color tab on the screen in question (two will appear), and running the interactive calibration routine.
Feb 16, 2010 | Apple Cinema Display 23" HD Monitor
Backlight is not working
eht coil generator which generates power for backlight tube is damaged change it
Nov 26, 2009 | Apple Cinema Display 23" HD Monitor
Oct 28, 2008 | Apple Cinema Display 23" HD Monitor
Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Screen resolution.
Hello there!
It's fortunately quite easy to adjust the resolution your MacBook Pro sends over to your external display.  Try this:
  1. Click the blue Apple icon, at the top-left of your display (while connected to your 23" external monitor).
  2. Click on "System Preferences".
  3. Click on "Displays" in the "Hardware" row.
  4. A display preferences window should now open on each display... one on your laptop, and one on the 23".
  5. In the "Display" tab of this preference window, specifically the one located on your 23" display, should be a list of resolutions available.  Scroll down and select the highest resolution, which for a 23" should be 1920x1200.
This should adjust your resolution to the maximum.  To make these settings easier to get to in the future, check the box in the display preferences labeled "Show displays in menu bar".  You'll see a small icon, meant to look like a display, appear in your menu bar.  Going forward, you can click on this to set/change resolution settings without going through all the above steps.
Hope this helps!
Oct 10, 2006 | Apple Cinema Display 23" HD Monitor
Apple 23" Flat-Panel TFT-LCD Cinema HD Display Logo
70 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
