Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite He3 HAS ERROR CODE F02 WHAT CAN I DO
  • 5,911 Answers
"F02" is a Long Drain error code. This is an indication that there's an obstruction in the drainage system somewhere. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the lower toe panel directly below the door in the FRONT of the washer. They are located under the bottom front edge of the panel. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor on these small drain pumps. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Posted on Feb 06, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
I have kenmore elite he3 and it is flashing f 02 and then it will flash sud. Water will not all drain out of it,
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 f02 error
from what i read the presure switch is bad or the presure switch hose is clogged,one guy took the hose off and blew in it and no more f2-mike
Jul 21, 2009 | Kenmore Washing Machines
Our Kenmore Elite HE3 washer will not finish a cycle, flashing an error code of F02. Can you tell me what this is in reference to?
"F02" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In general, this usually means the drain pump or drain hoses are clogged and need to be cleaned. I have included instructions on how to do this as well.
It does not take much to damage these small pumps. Items begin caught in the pump impeller for extended periods of time can result in a pump that no longer runs, or one that no longer pumps at the correct volume. If cleaning does not solve your problem, the manufacturer recommends replacing the drain pump. Hopefully, a simple cleaning will solve this for you. Let me know if you have any questions, or require addtional assistance.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer door will not open
The error code F-02 on the Kenmore HE3 means that the drain pump could not pump out all the water within 8 minutes. Not sure what this has to do with the door being locked,, but its also possible that if the machine thinks there is still water in the drum, or if in fact there is still water in the drum that it would keep the door locked as some sort of safety precaution
Mar 13, 2009 | Washing Machines
SHOWS F02 ERROR CODE
your drain pump is clogged. you must take the bottom panel off to acess. there is a draincock that you will unscrew but be advised that there will be a gush of water and then you will discover the small items blocking your drainflow.
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite - F02 trouble
Hi jbll,
The f02 code is always from a slow drain issue. This washer allows only 8 minutes for all the water to drain and if it is not gone in time you get the F02.
This is the proper check sequence for that problem.
Check the drain hose and make sure it is not plugged or kinked.
Check the drain pump filter for foreign objects. You can remove this easily and replace it if needed.
If the above does not correct the problem, replace the pump.
I hope this has helped, Lots of luck . Mike Anderson
mca0824@aol.com
May 02, 2008 | Kenmore 4292x Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
277 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
