Question about Reebok Vista Treadmill - RBTL13305
Treadmill does not operate; however, the hill climber activates fully up and fully down whenever the power is turned off and on.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 14, 2010
Tc/tm config rqd 1 on 425 hr clubtrack plus treadmill not stair climber
Perform the following steps to configure the treadmill.
  • Enter the service mode
  • For the HR ClubTrack Plus, enter the configuration by using the menu choices on the service mode screen, which should be CP3 for the HR Clubtrack Plus.
  • Press SELECT  to store the configuration. (For the HR ClubTrack Plus, select the Set Screen Contrast screen and use the contrast up and down buttons to select the optimum contrast. Select Enter to save the value.)
  • Exit the service mode and confirm proper function of the treadmill.
Jun 20, 2015 | Exercise & Fitness
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
Start shuts down machine and blows circuit breaker
see the video attached. and proceed according. However you must test the power cord for short circuit. some wires is touching each to another. Or the outlet wall the wires are loosing touching each to other and blowing the c.breaker, or call some electrician for to fix it.
God bless you
Oct 17, 2013 | Bowflex Tc5000 Climber Treadclimber...
E2 error lift error
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You have posted this question in the Stair Climber section, but the error you are listing is a treadmill error code. The following information should help.
Probable Cause A) Incline control error.
B) Insufficient power source.
C) User exceeds weight limit.
D) Unit will not lift.
E) Unit thinks it is always at 0% incline and only lifts up.
F) 3 amp circuit breaker has tripped.
G) CPU board has stuck relay.
H) Lift motor is faulty.
Corrective Action A) Access the incline manual mode in diagnostics by pressing 9, 1, 9, ENTER and then pressing HILL program key. Incline the unit with two people on the unit. B) Ensure treadmill is connected to a dedicated 120V, 20 Amp circuit.
C) Advise user of unit's weight limit of 300lbs (137kg).
D) Perform the lift test procedure by pressing 9, 1, 9, ENTER and then pressing HILL program key.
E) Inspect the home switch for smooth operation and inspect the wiring of the home switch for damage or poor connections. Inspect the lift motor cable connections and for the presence of the suppressor board (should only be 1).
F) Test the circuit breakers and replace if necessary.
G) Replace the CPU board.
H) Replace the lift motor.
LifeFitness 9500 Treadmill Lift Control Error
Jul 31, 2013 | Life Fitness Exercise & Fitness
Carl lewis mot 25 treadmill drive motor not getting power
Maybe the mouse is sleeping in the motor? First, try to release the treadmill belt pressure so that you can turn the rollers by hand. If all of the rollers turn except one, that is probably the drive roller. If you are careful you should be able to take the belt off and get to the drive roller and its motor. Check the motor is getting power. There is probably a reset switch on the motor, reset it. If it still doesn't turn..replace the motor.
Jan 12, 2013 | Sport & Outdoor - Others
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
Program shuts down during exercise. Resets to default program. As if rebooted. have all new parts,(alternator, key board, gray cable, resistor, power input )
I am having the same issue with my 4XXX StairMaster unit.
I am suspecting that the voltage regulator on the lower board is at fault and that a lower board replacement is in order. I have checked everything else (motor, resistor, power supply).
Try this:
My machine REBOOTS if I choose:
- Rolling Hills
- 200 lbs
- Difficulty 20
- 20 minutes
My machine OPERATES NORMALLY when I choose:
- Rolling Hills
- 200 lbs
- Difficulty 1
- 20 minutes
Apparently, the problem only manifests itself at HIGH RPM, which is probably related to a LOWER BOARD / VOLTAGE REGULATOR issue.
Graham Leach
Apr 12, 2011 | Stairmaster 4400 PT Stair Stepper
How do I fix my Endurance Treadmill TF3i Err7 problem? I stopped during operation.
Unplug unit remove motor shroud check connections on lower board (incline board). I believe their is a 3 amp fuse in circuit check with multi meter to see if open replace fuse power up unit and if it blows the fuse then replace incline motor and if not, then use engine mode press stop then Incline + or - to force incline up to max incline then bring it down to 0 then turn off power then wait 10 seconds then hit power on then if error does not appear then hit start and resume using unit. If the procedure above does not activate unit then replace board.
Apr 15, 2010 | Endurance T3 Treadmill
No pep whenever the car goes up a hill it has no
First of all, the transmission should be down shifting when under load. Staying in o/drive up a hill will only bog the car down. Have the trans. checked.
Jan 06, 2010 | 1997 Oldsmobile Achieva
Incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Oct 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Reebok Vista Treadmill - RBTL13305 Logo
97 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
