Question about Dell Dimension 3000 PC Desktop
Dell dimension 3000 memory card
I upgraded memory stick from a 512 & 256 to 1gig, got a scrambled screen. replaced the old cards and got a beep code. Installed a 256 video card, with 1gig I get the bios page to come up but does not finish booting up. With old cards, beep code.
  • 1 more comment
  • sppac Feb 21, 2008
    Dell Dimension3000, DOM July 2005. I tried reseting memory stick several times, swapping slots (initially installed in slot #3) When I reverted back to the original setup all I got was a beep code. I now have a GYYG light code. I can't find what that code means. With original cards I get YYGG, which indicates a memory problem. I slaved the hard drive to an old PC to save some files and clean up the disk, the hd seems to work fine. A couple of times while trying to boot the new PC, I received a message (trp2) contact Dell. I'm about at my wits end. I am only running a single 1gig card, would it help to install another one?
  • sppac Feb 22, 2008
    The OS is whatever came from the factory. HD is a western 40gig with XP Home edition. I did call Dell but the guy seemed the think that something in the mobo went bad, he wasn't sure. That's the reason I installed the Video card, I thought that perhaps the built in card couldn't handle the extra memory. I can't get into the system to install the drivers, though. Could this be an issue?
  • sppac Mar 15, 2008
    Ok, I have a new MoBo for a Dell 3000. My new question is: Should I use a low memory card and install the video card software before I install the 1gig card?
    Scholar:
  • 121 Answers
If your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Posted on Feb 21, 2008
  • donna mcgill Feb 22, 2008
    yikes, it sounds like you have tried everything and unfortunately it seems to be a bigger issue than i think we both thought it would be.. i know many of my friends that had a dell always had issues but it seems to be the way pc's are going these days unless to actual buy a workstation or something like that.. as for adding more memory, yeah that may help but i hate to see you spend the money and then still have to contact dell to find out you didnt need to buy that extra..mmm what os are you running on just out of curiosity?
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
I have abrand new Dell XPS 8100 with upgraded memory to 8mb and an ATI 5770 graphics card. When I start the computer I get 6 beeps and the PC does not start. Fitted a replacement Graphics card, still the...
Depending on the main board, 6 beeps usually signify's either a RAM issue (like a bad connection or incompatible ram) or an expansion slot issue so check any other cards you may have installed and make sure that The new RAM stick is compatible with the main board.. The main board model code is printed on the main board. Use it to search for audible fault codes, or go to www.upgrading and repairing computers.com and search for the beep codes for the main board on this site. Also, try reseating all the RAM sticks and expansion cards, especially graphics card..make sure you have not dislodged any data connectors and double check everything..
Feb 05, 2010 | Dell XPS 200 PC Desktop
I have a dell Dimension 8250 and replaced the memory cards with a higher memory. I got a memory error beep code so I replaced the original. I'm still getting the beep code. Any ideas? I was careful...
Please check the following link for complete information on Dimension 8250
http://support.dell.com/support/edocs/systems/dim8250/
Check the technical specification section to see if u bought the correct memory type for this computer to upgrade..if yes then proceed to the adding and replacing parts section to check for the instructions on adding memory.
Jun 27, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
PC can't boot LEDs are all Amber colour and flashing.
the memory sticks are not connected properly as you are getting the beeps out of the computer when turning on...
if in case the memory cards are connected properly the system should not beep while turning it on so please try to reconnect the memory cards properly & see if you are getting the prompt"the amount of system memory has changed" coming up in that case the system is working fine.
May 07, 2009 | Dell Dimension 3000 PC - P4 2.8GHz/256MB...
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
Memory upgrade in Dell Dimention 3000
Please take one of the memory cards and try and try the same card in all the slots also try the second memory card. Also check if your getting the memory beep at the start up and dell diagnostic lights all the lights should be green
Jul 21, 2008 | Dell Dimension 3000 PC Desktop
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
475 people viewed this question
Alun Cox
