How to clear Code C3451 on minolta bizhub 350 - can't get into tech mode
    Problem Solver:
  • 5 Answers
Try turning the unit ON while holding down the utility/counter key and wait for Trouble Reset to pop up on the display
Posted on Feb 14, 2010
How to reset error c3451 in konika minolta 215
clear/stop held down and turn the machine on, IF THIS CODE COMES BACK DO NOT RESET AGAIN IT IS POINTING TO FUSER UNIT IT CAN CATCH ON FIRE GET TECH OUT AND REPLACE THE FUSER
Feb 14, 2014 | Konica Minolta bizhub 200 Printer
Rebooter
The problem is in the fusing unit,fuser warm up error.Enter in the service mode:Press utility key Meter count key introduction 00000000 press enter select trouble reset.
Jan 24, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Malfunction detected c3451
gives the corresponding malfunction code and maintenance call
May 17, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Konika minolta bizhub 350 Error c3451
error c3451 is abnormal heating temperature. al you have to do is reset the machine. open the back cover and on the main board look for a micro switch. press it will the machine is turn on. i hope this will help you.
Sep 16, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Getting c2557 code how do I fix? on bizhub 350
Welcome to Fixya
Sounds like you nee to replace the developer. Try to reset the printer first. Enter the service menu by pressing utility > original size> stop>0>0>stop>0>1 the password is 00000000, in the service menu select tech mode, go to counter and clear the life of the developer and drums and then run F8 from functions.
Thank you for using Fixya!
Jul 02, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Getting c3451 error
There is no c3451 code in the bizhub 350 service manual.
Feb 20, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Bizhub 250/350 Konica Minolta it has a
the device takes too long to warmup. try switching off then back on when you see the message. if that does not work you will have to call for a technician i'm afraid. good luck
Apr 09, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I have code c3451
Power off using left side rocker switch.
Power on while holding utility counter
Press trouble reset.
Cycle power (rocker)
If it comes back immediately you need to replace the fuser.
Mar 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
Sep 01, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
258 people viewed this question
jasbo
jasbo
