Question about Car APS921 Remote Starter - Keyless Entry
I bought a car with this starter (below)and no one knew how to use it. Does anyone know what buttons i push to start the car and open the trunk? Thank you REMOTE MADE FOR: Audiovox ® BUTTON: 4 LED or LIGHT: RED BOARD#: 433Mhz FCC ID: ELVATOE P/N: PROOE4BS OTHER TRANSMITTER REPLACEMENT (S): YES (ANY PRESTIGE APS2K4 REMOTE) PROGRAMMED BY: CUSTOMER INSTRUCTIONS PROVIDED: YES FEATURES: LOCK, UNLOCK, TRUNK/START, OPTION WORKS WITH: PRO9675FT4 PRO-9775 PRO-9800 PRO-9349FT PRO-98BTKD SS-CIT-1
I'm not sure about trunk but to start the engine press twice green buttun and engine should start and to shutt it off press green button once.
Posted on Jul 22, 2010
  • 1 more comment
  • legale50 Feb 14, 2011
    thanks so much! i thought it needed a new battery!!!! i love the internet......
  • the swiftnes Feb 19, 2011
    to open the trunk you hit and hold the green buttom.....it takes about 10-15 secs to register
  • julian Feb 05, 2013
    how do i turn the kat when i get it?
I have a 2004 chevy Malibu would anyone happen to know Is there a way i can get Into my trunk from the inside of my car, my key stop working to the trunk and so did the trunk release button, all of my...
There is a relay in the rear fuse block for the trunk release. marked trunk relay #36. It is marked on the under side of the lid. If you knew how they worked you could open it by jumping pin 30 to pin 87 in fuse box. on the side of the relay is a diagram of what pins are what . This system uses an electronic control module called ( the BCM ) body control module .When you push the inside release button , that sends a signal to the BCM ,then the BCM activates the relay opening the trunk . Well that won't help ,you won't believe where the fuse box is ! Fuse Block - Rear
In the rear compartment, behind the left wheel well. You could jump the wire at the BCM that goes to the relay. Can't you pull down one of the rear seats to gain access ?
Dec 27, 2014 | 2004 Chevrolet Malibu
The trunk release buttons on my 1995 Olds 88 starts the car but does not open the trunk!
Seems to me the auto start and your factory key fob have the same freq. if it is a factory remote start there is something crossed somewhere. You should be able to find a disconnect switch for your remote start somewhere( in fuse box area or underneath the dash) once found follow the wire to the remote start receiver. Visually check wires and try and get a make and model number of the remote starter. Google the wiring diagram for that type of RS.
Nov 18, 2014 | 1995 Oldsmobile Eighty Eight
How to open trunk jeep Cherokee from inside
all cars , have child protection. for 20 years now.
read the operators guide. it's in the glove box , on door locks
the driver can block and prevent passengers in all rear areas from egress.
child proof.
they never knew you'd put up a barrier.
How would they, that is all custom modifications.
incase you lost it so soon, here it is for free.
http://www.jeep.com/en/owners/manuals/
on some cars its just master switch
excerpted from my op guide.
Child Protection Door Lock
The rear doors of your vehicle are equipped with child
protection locks. If you push up on the lever on the open
edge of the door it cannot be opened from the inside of
the vehicle. Push the lever down to disengage the child
protection locks.
in your manual read page 36, see photos there too.
page 38 , shows what to do if stuck inside.
all in the manual.
May 17, 2014 | 2013 Jeep Grand Cherokee
98 Ford Taurus ignition key starts car but won't manually open trunk
I'm guessing you bought the car used this happened to me and it was because the trunk had been replaced from a wreck and thus ended up being keyed different A locksmith can make you a new key otherwise its a pain Cuz if the battery goes dead you can't open it
Apr 22, 2014 | 1998 Ford Taurus
Trunk button is starting car
If there is an aftermarket remote starting system , an "alarm/stereo shop" can disable or remove the unit for you.
Jan 30, 2014 | Toyota Camry Cars & Trucks
Harley starter
Hi Anonymous, get out your test light and check the start button for continuity if ok track the wiring to the starter relay and solenoid your contacts could be welded, for a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
May 01, 2013 | 2006 Harley Davidson FXSTDI Softail Deuce
I just bought a car that came with two Pursuit PROOE4BS remote I can only get the remote starter to work but after the car starts2c if I enter and depress the brake2c the car will turn off Also I can27t...
if you enter the car after you used remote starter,dont depress your brake.you need to put your key(insert) into your igniton barrel
and turn it in to ON possition(dont crank the starter) now you can depress your brake to cancel the remote start.and your door lock and trunk maybe the installer didnt connect the wiring from remote starter to your car...
Feb 09, 2010 | 2004 Lexus ES 330
Trunk not opening!!! How can I bypass the button & I need a free, possilby downloadable owners manual
hi there i have a mercury cougar 1987 and they are the same thing if your car at the door ajar is a keyboard search at ther trunk the code to open de car and then try to open the trunk check the open mechanism on the trunk sometimes is unplug or clean it a little bit if it donesnt work yo may buy the button at a yunk yard. the manual is only for sale at your local store like kragen, pepboys autozone etc. i bought at one of those places
Jun 01, 2009 | 1988 Mercury Cougar
Keys in trunk
go to dealer with VIN # and get a new door key cut easiest thing I am not sure what the cost would be but if the ign and door keys are the same he could opt. not to get the programmed key
Dec 23, 2008 | 1997 Lincoln Continental
Trunk will not close
With the trunk open try to accuate the button on the driver's door, check the state of the lock in the trunk first and see or have someone watch it if it moves when you push the door's button.
You may also try manually to open the lock right in the trunk.
Jun 10, 2008 | 2003 Cadillac CTS
Car APS921 Remote Starter - Keyless Entry Logo
1,799 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
