Paper Jam?! I work for an e-waste/recycling business in Ohio and we got a TON (literally) of Dell Laser MFP 1815dn and 1600n all-in-one systems in. I'm checking them to see if any are still useable or possible resale. Here's the issue: I load in the paper and toner I go to scan/copy something. The paper is pulled through, scanned and then spooled. The systems starts to whirl as if beginning to copy, but then I get the same error on over half of the machines that power up "paper jam 0 open front door". If I open the front door I see nothing; even removing the toner reveals nothing. There is no paper jam (I fell like I'm in office space)! Are there sevsors or something that just need cleaned that would fix this issue?
I have the same issue with ~ 10 of these machines. I just raked Dell over about them and they are sending 10 sets of new feed rollers and 20 paper trays... I expect this 'shotgun' approach is going to resolve the issues for 6 months or better.
Posted on Aug 11, 2008
    Genius:
  • 1,019 Answers
did you ever wonder why they were in the waste in the first place. ?
If you,ve got lots of them, you could experiment by swapping parts over, from the others which may have different faults.
hope this helps Mike @ Compurepair.
Posted on Feb 21, 2008
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
How can I get it to print the ip address to hook it to my computer
Dell Laser MFP 1815dn configuration page
To print a configuration page (also called system data report) from a Dell Laser MFP 1815dn printer:
- Press the right arrow button until Menu is the active choice on the screen
- Press the check mark button to select it
- Press the right arrow button until Reports is the active choice
- Press the right arrow button until System Data is the active choice
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Aug 21, 2015 | Dell Office Equipment & Supplies
The document cover is missing on my used Dell laser MFP 1600 . What can I do to resolve this problem?
If you need to make copies from glass then cover top with a 11X17 paperthis will insure the ink is not wasted copying a darker lid.
Sep 05, 2012 | Dell Mfp 1600n All-in-one Laser Printer
My dell mfp 1600n will not feed paper without jamming in the auto feeder...what is wrong?
if the problem is with the paper from tray, suspect the rubber tires on the pick rollers are bad. You can remove them and flip them inside out and reinstall
Dec 31, 2010 | Dell 1600n All-In-One Laser Printer
I dont know how to send a fax using the Dell laser MFP 1815 dh
Here is a link to the Dell website where you can download the user manual for the MFP 1815dn. I just looked and it has a complete section on how to use your fax...
http://support.dell.com/support/edocs/systems/prn1815/en/index.htm
Sep 10, 2009 | Dell 1815dn All-In-One Laser Printer
Scanner locked printer dell laser mfp 1815dn
The lock for the scanner is on the roof of the cavity where the printed paper comes out. Simply flip it to the other position and restart the printer.
Jun 03, 2009 | Dell 1815dn All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Computers & Internet Logo
456 people viewed this question
Alun Cox
David Payne
David Payne
