Question about Aprilaire 400 Humidifier
No water going to humidifier
I replaced filter. Not getting water past the solenoid at the base of humidifier. We have hard water here, could that have clogged the solenoid?
    Problem Solver:
  • 19 Answers
Easy fix: Check the solenoid. Turn off the power to your humidifier and the central air unit. On the side of your humidifier is a brass solenoid. It can get clogged with lime and calcium. Most videos and instruction manuals tell you to replace the solenoid. No need if you can turn a wrench.
1. After all power is off turn the water off to the humidifier and disconnect the top line water line at the nut.
2. Disconnect the bottom line water line that will go to your humidifier.
3. Take a Philips screw driver and remove the two screws that hold the solenoid on the side of the plastic housing of the humidifier.
4. Leave the wires connected unless you need more room to work. If you disconnect the wires then label them with tape (colored) so you put them back on correctly.
5. In the inlet or outlet water pip of the solenoid is a trainer that may be clogged. With a paper clip pull it out and clean it. If it’s clearly clogged then stop and put all back together. That may have been your problem.
6. If it’s not clogged then it may be clogged inside the solenoid.
7. The nut on the end of the solenoid is silver. Take it off and the magnet (main power unit) will slide off.
8. Notice the flat head screw post on the end of the solenoid. Turn it and remove. Be careful as a small spring loaded plunger is inside.
9. Take apart and clean all parts. You should be able to blow air in the intake water line tube and it go out the out water line tube as well as were the plunger hits in the center of the solenoid. If not then it’s clogged.
10. If clogged then just soak all but any parts with rubber or plastic in a small white vinegar solution for a couple of hours to eat away that lime. If it’s not clogged then you probably have a bad solenoid.
11. To check and see if the solenoid is bad just put it all back together but do not re-wire the solenoid to the humidifier.
12. Turn on everything without the wires going to the solenoid (turn on meaning put power back to the unit.
13. When the system is running as it should without the humidifier and solenoid wires attached check the two lead wires with a volt meter for 24v. If you have 24v then you have a bad solenoid and need a new one. If no 24v then you may need a new control panel.
Hope this helps you out.
Posted on Dec 30, 2009
  • 123 Answers
It could have. Use vinegar and allow it to sit. This should break down the hard water deposits. Good Luck.
Posted on Apr 18, 2008
Aprilaire humidifier 110
Hello, typically solenoid valves should be replaced every 7 years and they are not very difficult to replace. Just need to shut off water at saddle valve, turn off power to humidifier, and remove mounting hardware. Here is a link to store which sells the solenoid needed for your humidifier. http://www.aprilairehumidifierparts.com/product.php?p=aprilaire_4005&product=111011&category=1686
Dec 18, 2012 | Aprilaire 700 Humidifier
Humidifier doesn't work
Hello, if there is water to the solenoid valve but not passing through it than the solenoid valve is malfunctioning and must be replaced. However, if there is no water at the solenoid valve then either the saddle valve or supply line is clogged with sediment. A easy way to chek the solenoid valve is apply power directy to the solenoid valve from the transformer, if it does not open then replace it.
Nov 17, 2011 | General Filters 1099-LH Humidifier
There is no water going into the humidifier, make: Generalaire 1042
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
Apr 09, 2011 | General Filters 1042-LH Humidifier
Frequent knocking noise coming from General Aire 1042 LH humidifier
Hello, it depends where the sound is coming from,if it's in the supply water line it could be caused by water hamer or the inlet side of the solenoid valve might be clogged up with sediment. Water hammer is when the solenoid closes under high water pressure and a water hammer arresters should be installed. If the sound is coming directly from the solenoid valve and is more of a chattering sound then there is a loose low voltage wire or the solenoid is going bad. If you disconnect the power to the solenoid and the chattering stops then solenoid must be replaced as it is the cause of the noise.
Mar 17, 2011 | General Filters 1042-LH Humidifier
Loud Ringing or buzzing noise off and on from the humidifer. Do we just need a new filter?
Hello, usually a ringing or buzzing sound comes from the solenoid valve on the humidifier. Make sure that the solenoid valve is getting a solid stream of water to it, sometimes if there is not a good stream of water the solenoid will buzz. if that checks out good than replace the solenoid vlave.
Feb 10, 2011 | Aprilaire 550 Humidifier
I just installed a Hamilton whole house humidifier but am not getting enough water to the filter. The solenoid is opening for 2 seconds every minute to release the water as it is suppose to do, but the...
Most humidifiers have a strainer on the inlet side of the solenoid valve, if this strainer is clogged up it will reduce the water flow to the humidifer. Usually sediment builds up in the strainer and all you need to do is remove it and clean it up and reinstall it.
Jan 19, 2011 | General Filters 1099-LH Humidifier
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
Water is getting to my solenoid valve and the valve is activated as it is warm to the touch. No water on the back side of the valve to the humidifier. It is on sometimes and other times is doesn't work....
Valves do go bad, but I had the same issue and it was the inlet orifice that was plugged.
To fix: Turn off the water supply. Disconnect the water inlet line to the solenoid. The water inlet line connect to ~ 1" long piece that goes into the solenoid. Unscrew the water inlet piece and remove it from the solenoid. Check it for water flow - water should slowly drip out the small orifice at the soleniod side. There is a pin-hole sized orifice on the solenoid side and it doesn't take much to plug it. There is also a narrow cone-shaped filter inside the inlet piece. You can use tweezers to remove the filter and & use a safety pin or sewing needle to clear the orifice. Check the filter, clean it if necessary, and reinstall the filter. Now check for water flow thru the part before reinstalling. Reconnect the water inlet line and turn on the water supply. Turn your humidistat to trigger the humidifier. You should see water flowing through the drain tube.
Dec 13, 2009 | Honeywell HE220A1019 Whole House...
Aprilaire 760 won't start
No. when you remove the front cover it will automatically disconnect the power supply. Try changing the water panel and cleaning out the orifice and filter screens located in the water lines connected to the solenoid valve.
Dec 26, 2008 | Humidifiers
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Aprilaire 400 Humidifier Logo
1,588 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
