Question about Arrow T50P ARROW STAPLE GUN
Arrow T50P gun jammed - how do you unjam it?
My Arrow T50P staple gun is jammed - how do you unjam it?
    New Friend:
Buu a different brand or model this one is junk and should be taken off the shelf
Posted on Nov 07, 2014
5 Suggested Answers
  • 623 Answers
SOURCE: I cannot figure out how to load an Arrow T50P
Turn it upside down. On the end opposite where the staple comes out look for a tab on each side you squeeze to release the staple holder, the staples go in to this holder upside down as well, just push it back in until the releases catch and hold it in. Hope this helps.
Posted on Jun 21, 2010
  • 240 Answers
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
  • 32 Answers
SOURCE: my arrow staple gun jams every few staples even
no sutch thing as jam proof hehe.
just squirt some oil in the gun and you should be good to go.
Posted on Nov 10, 2009
SOURCE: how to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Posted on Aug 20, 2009
Unable to load my Arrow Fastner Model JT-21. Can you help?
is there a problem with it? here is a manual that has pictures. If you have a jam or something, repost what the problem is.
Aug 09, 2011 | Arrow T50P ARROW STAPLE GUN
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
My T50P will not discharge staples. I'm using the correct staples, there is no jam that I can see, and everything is well-lubed. It seems like the driver is not retracting far enough to allow a staple to...
sometimes mine won't shoot, and i find a single staple in the track, almost ready to fire out , but can't , they can be hard to see in the tract, i keep sharp pliers on hand to clear them. hope this helps
Sep 30, 2010 | Arrow T50P ARROW STAPLE GUN
I cannot figure out how to load an Arrow T50P staple gun
Jun 17, 2010 | Arrow T50P ARROW STAPLE GUN
My arrow staple gun jams every few staples even thought it has a ''jam proof mech''
Nov 10, 2009 | Arrow T50P ARROW STAPLE GUN
Stapler is jambed
a staple is probably jammed in between the housing and the ram look at the bottom front where the staples are ejected you may need a small screwdriver to reach up inside and loosen the staple from the ram ... a little WD-40 may help also ... dont forget to rate me thx:)
Oct 01, 2009 | Arrow T50P ARROW STAPLE GUN
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
Arrow T50P ARROW STAPLE GUN Logo
632 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
