Question about RCA P52926 52" Rear Projection Television
My TV stopped working. I found a fuse blown on power cord circuit. Replaced fuse and now works but the picture is fuzzy and bends at the top and bottom. the colors dont appear to be lining up. What can I do.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Heat is the number one enemy of electronics, and these sets operate hot. This problem is caused by the power supply being overloaded. This is often caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. This model of TV has over 3,000 parts which include millions of transistors inside the integrated circuits. Over time the capacitors will change value, leak and become defective. Resistors will change value and burn. This will cause other components to become defective. This can has a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
The home theather just stop working in the middle of a movie
Hello Sounds like the power board has blown. If you want you could take the cover off and look to see if there is a glass fuse it would be near were the power cord attaches to the circuit board. See if it is blown, if so replace, you may have had a weak fuse. But more than likely you have a defective power board, and the system will need to be service, or more economically replaced.
Thanks the Projector Guy
Apr 21, 2010 | Philips Audio Players & Recorders
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
Power problem
If you don't have any indicators working, you have probably lost your power supply. With no picture and no sound the chances are you have either lost the power supply or blown a fuse. If you remove the cover and look at the circuit board there is a fuse located near the rear of the chassis near where the power cord connects to the chassis. If the fuse is blown, it is advisable to replace your damaged power cord before replacing the fuse. The cord could have a short and this could create a fire. Be very careful when working on any television. Be sure it is unplugged for more than one day to allow the high voltage to decay from the picture tube. Do not touch the picture tube, it still may have some residual voltage and could shock you. If you replace the cord and fuse and still have the same problem, you will probably find that the high voltage transistor is bad and needs to be replaced.
Jerry
Nov 07, 2008 | Philips 36PT842H 36" TV
Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Sep 16, 2008 | LG WFT1071TP Top Load Washer
42 ' LCD tv spectroniq
did you check the control board on the back of the TV there might be a blown capacitor that could be replaced like on the polaroid ones found on this site. pretty clear info on that tutorial and could work on this one too
Aug 16, 2008 | Spectroniq PLTV-42HW68 42 in. LCD TV
Trutech tv model #PLV16260
Heres what mine did:no picture no sound, when i hit the remote the indicator light went out....piece of crap is six months old, cant find any info on it, cant get a hold of anyone at Trutech.
So i took it apart, on the board that the power cord is attached to, i found six blown capacitors. There is also a big ass one in the middle of that board which looked ok but blew out the bottom.I replaced them, and im watching it as i type.
Its fairly easy but if your not comfortable soldering on a cheap circuit board, take it to someone.
I hope it helps, i think this repair will fix the other Trutech models with the same problems.
Eric
ed44309@hotmail.com
Nov 22, 2007 | TruTech PLV16260 Television
Panasonic model CT-36SL13G TV
Your problem is most likely the thermistor , or degausser, is going bad. It is a little black box with pins and says D1R5M on it. It can be found by following the wire from the degaussing coil around the picture tube. The location number is CF803( i think)the Panasonic partnumber is D4DF1R50001. Also, I believe your fuse is 6.3A not 3.6A.
Nov 07, 2007 | Panasonic Digital Video Duplex, Color...
Fuse Blowing
A blown fuse is usually caused by a shorted regulator or a bridge rectifier circuit. Either way it is a problem in the primary power supply. A bad cord won't blow the fuse in the set, it will blow a circuit breaker in the house. A servicer usually would normally cover the inside of the set with a "few light slits in the AC cord". Hope this helps
Jun 02, 2007 | Sylvania 6626LCT 26 in. LCD Television
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
RCA P52926 52" Rear Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
